Nigel_
Flight distance : 388642 ft
fans20b4b055 Posted at 2017-7-4 15:41
Well that is a bummer since I bought the drone specifically for this trip. We will be going onto land at times so I can definitely fly/shoot from there. I've read elsewhere that relying on RTH while on the water with the ship moving is a problem in and of itself (I usually had catch for what it's worth.)
I hope I will be able to keep LOS but if I want to circle around some of the huge ice formations - also a high priority - that might not be possible.
Haven't found any insurance that will cover a lost drone, so betting the farm on being able to control it. Not sure I will have enough flight hours, but hoping for the best. And we will be in a bay in the southeast coast of Greenland, so that might give me a little better odds (heading to Iceland after the trip but doing mostly actual aerial photo there in a Cessna 210.)
RTH works fine over water if there is GPS, the only problem is that the ship may have moved. Even if the ship is at anchor the tides can move it around to the other side of the anchor which can be far enough that you don't see the aircraft when it returns - you need to be able to use the map display, practice using the map to land away from the launch point before going.
If you are circling around icebergs, make sure that you stay high enough that the aircrafts view of the southern horizon is not blocked, if you loose GPS behind an iceberg/hill/ship you will be in trouble with no RTH - gain height to try and get the GPS back, if you also have control signal blocked then you need to move the ship and the battery will be flat before you succeed!
You may be OK in the south east, the north west is the worst, big difference. If you are going to take the risk of flying from the ship, power the drone up and take off from a point as far away from metal as possible, even if you have a wooden deck it will have metal below, taking off from on top of a plastic bucket can easily make the difference between crash or success.
Avoid calibrating the compass while you are that far north, set the maximum height to maximum so that if you need to climb to get GPS back you wont get stuck while still too low. |
