wataero
Flight distance : 1719619 ft
I only have experience with the P4P+ so...
3) Yes, it is bright enough that you don't need a hood.
4) Actually, it is the opposite, the + RC is missing many of the features you get when using the GO 4 app on an IOS device. Even when DJI updates the software on the + RC, it is not up to the capabilities of the IOS version. For example, several of the flight modes are missing options, i.e. in Activetrac you are supposed to get 3 options, on P4P+ you get only 1. Also, waypoint mode is basically useless since you don't have option of controlling where camera is pointing as it flies. In addition, you cannot run any of the IOS apps such as mapping apps. Finally, instead of downloading updated GO app from app store, it only comes as part of a firmware upgrade, a bug ridden process that usually involves several resets, reboots, reloads, calls on hold to tech support....
