stuka75
Flight distance : 85682 ft
Before you solder, you need to know what wire is the issue. If there is an obvious wire shorting then it could be soldered. If the stick still centered properly, then its electronic or electrical. Try jiggling wires around the stick without moving the stick while its connected to the ac. Otherwise new controller or sending it in could be done. |
