new forum member & checklist
1600 14 2015-3-18
mark
Been a Lurker here for a while while I waited for my Inspire 1 to arrive.
Ive got so much info from this forum so big thanks to you all.
I hope I can contribute as I learn more.
I have put together a full single operator check list which you may find of interest if I can work out how to attach to a post.
SEE BELOW
cheers
Mark Candlin
2015-3-18
mark
Here is my checklist feel free to use and modify if you want, let me know if Ive missed anything and I will amend.
Designed for A4 size
Mark C
INSPIRE 1 Checklist by Mark Candlin.pdf
357.03 KB, Down times: 136
checklist
2015-3-18
msjh
About to order my Inspire and been looking for something like this.  Thanks!
2015-3-18
Ph02on
Flight distance : 75673 ft
Welcome and Excellent list.  However as others have suggested elsewhere, it may be a good idea to do the compass calibration before you mount the props, in case of an accidental motor start.
Cheers.
Jason
2015-3-18
rodger
Flight distance : 20145135 ft
mark@surreysign Posted at 2015-3-18 23:56
Here is my checklist feel free to use and modify if you want, let me know if Ive missed anything and ...
Good job and welcome to the forum.
2015-3-18
rodger
2015-3-18
Wildcat Willie
Nice work Mark...Looks like you put a lot of thought and effort into it. Very professional. I will integrate it into my checklist with the only change to max altitude. In Canada it is 300ft not 400...
Many thanks for the effort and sharing.
2015-3-18
mark
Jason, Seems sensible, noted and will amend and repost
2015-3-18
Dangair
Jason, no need to do that. There has never been a reported instance of a rogue prop chop during calibration. If you are concerned about it, it is possible to hold the aircraft in such a fashion as to not put body parts in harms way. Furthermore, if you do the calibration as is suggested, each time you turn the aircraft on, you will be consuming a great deal of time with the aircraft idling away while you prop it, which by the way you will be doing with the aircraft powered up? Unless you turn the aircraft off... Which leaves you open to a lost calibration. Myself personally, I leave er running props on and ready to rock, carefully knuckle on to the frame from the underside with the intent of staying out of the ginsu path of the props, do the dance... Throw it on the mat and let er rip. Haven't lost any parts yet!
2015-3-18
markaguille
Flight distance : 2031818 ft
Guernsey
Thanks for the checklist Mark. Just printed one out, this will be going into my case for my next flight.
2015-3-19
mark
Version 1.1 attached, shows to use caution of props when calibrating compass. Jason has a good point about safety but as Dangair points out it would mean shutting down again and possibly losing calibration. As long as the pilot knows to use caution I think its ok.
INSPIRE 1 Checklist by Mark Candlin V1.1.pdf
357.07 KB, Down times: 46
2015-3-19
rustysilverwing
Flight distance : 7962966 ft
mark@surreysign Posted at 2015-3-20 00:04
Version 1.1 attached, shows to use caution of props when calibrating compass. Jason has a good point ...
add stop recording before power down
2015-3-19
Back to One
i  am no idea now . cause dji already have a quick start guide.
2015-3-19
pops52
Nicely done. Thank you for sharing it with us Mark.
2015-3-20
rsghowellnj
Flight distance : 508255 ft
Nice work on the checklist!  Like it .... thank you for sharing
2015-3-20
