[RESOLVED] MAVIC KEEPS RISING .....HELP .
1621 9 2017-7-5
fans9b88ba96
HI  can anyone help please I've just updated my mavic pro .when I take off now and just let it hover my mavic just  slowly rises without me doing anything and if I put the stick Down to lower the drone nothing happens until stick is all the way down and it says drone landing Can anyone help me out were
Many thanks
Doug
2017-7-5
Nelsonlee
Flight distance : 2779203 ft
Malaysia
After the firmware update you should do the following steps before you take to fly.
1.Calibrate the RC stick.
2.Calibrate aircraft (IMU)
3.Calibrate aircraft (Gimbal)
4.Calibrate aircraft (Sensor) by using DJI Assistant 2 software.
5.Compass calibrate the aircraft.
Hope this will solve your issues.
2017-7-6
Lok Mavic
Flight distance : 1486660 ft
Sounds like a normal behaviour to me. The Mavic will rise to 6m height for the VPS to work properly.
2017-7-6
Eagle_Eye
Flight distance : 4137720 ft
Make sure that the sensors @ the bottom of the MP are dirt free.
2017-7-6
fans9b88ba96
Nelsonlee Posted at 2017-7-6 00:14
Many thanks will try
2017-7-6
DroneFlying
Flight distance : 10774613 ft
A better option than calibrating everything -- which may lead to other problems if done incorrectly -- is to upload the DAT file from one of the flights where this occurred. The instructions for retrieving the DAT file are here, and once you've accessed it you'll need to upload the file to DropBox (or something similar) and provide a link to it in this thread. Once that's done, someone will look at it and may be able to shed some light only why this happens.
The last time I saw a DAT file from one of these it turned out to be a problem with VPS and the problem went away once the owner exchanged his Mavic for one that didn't have that problem.
2017-7-6
Six6Sics #666
Flight distance : 164236 ft
Had the exact same issue yesterday..... have done full recalibration but have not tested to see if issues have been overcome (yet)
2017-7-6
fans9b88ba96
Many thanks all back to normal
2017-7-7
Nelsonlee
Malaysia
fans9b88ba96 Posted at 2017-7-7 06:13
2017-7-7
Griffith
Flight distance : 98537 ft
Did I miss something?  Can you mention how the issue was resolved?
2017-7-7
