Mavic pro serial number
54364 17 2017-7-7
fans394eab47
Flight distance : 4843 ft
Can anybody tell me where the serial number is on a Mavic Pro
2017-7-7
hallmark007
Flight distance : 9827923 ft
If you turn on Mavic go into app and go to menu i.e. 3 .... dots go to about in there you can find S/N for aircraft and RC.
2017-7-7
fansf8325fcb
Flight distance : 3751693 ft
Peru
Remove the battery from the Mavic and there you will find the S/N
2017-7-7
DJI Natalia
Flight distance : 318 ft
The aircraft S/N can be found inside the battery compartment, here is the screenshot for your reference: SN.png
2017-7-8
fjrmann
Flight distance : 168438 ft
It is also found on the back of the box your mavic was shipped in from DJI
2017-7-8
BradBowers
Be careful - if you have previously sent back you drone/purchase in the box in came to you in, then wen it is returned from DJI and is a "new" (refurbished) drone, then its SN number under the battery wMAY be different from that on the original box - or, they may stick a new label which matches the SN number or they may not.  I'm on my third replacement drone within less than a year - all new numbers (under the battery, different from the box.
Brad
2018-8-23
BradBowers
I have no idea why my grammar/punctuation/spelling came out so bad on my previous post.
2018-8-23
fans09b66ddd
Flight distance : 130062 ft
Hi all,
where can we find or ask for the serial number of a mavic back guarantee but lost?
2018-9-10
InvisibleName 7
Flight distance : 795653 ft
fans09b66ddd Posted at 2018-9-10 09:33
Hi all,
Not sure what you’re asking
2018-9-10
fans09b66ddd
I lost my Mavic 2 months ago, and I just found an ad that sells a Mavic in the same village without any accessories or remote control. So I would like to check if it's not mine.
Then is it possible to block it (like an Iphone), or to geotag it if it is activated?
Best regards
2018-9-10
fans078f5a57
Ukraine
163dfa80001p0p4
2018-12-19
djiuser_mj5iBiBzxX3J
I can not locate the serial number on a Mavic 2 Zoom under the Battery. Nothing there says SN #
2019-1-7
Jaw787
For some reason, DJI does not tell you that the controller has to be connected to the drone through the DJI App. Once ‘connected’, go to the three dots in the upper-right of your screen. Go to ‘ABOUT’, scroll down all the way and the ‘N/A’ will be gone, and the serial number will be there
2019-2-6
Jaw787
hallmark007 Posted at 2017-7-7 02:36
IMPORTANT:  Drone has to be ‘on’, and connected, otherwise the S/N will say “N/A”
2019-2-6
Picanoc Jack
Flight distance : 10321657 ft
fans09b66ddd Posted at 2018-9-10 23:41
bring your controller to the shop and turn on the mavic and your controller,  if it starts fly the mavic out of there, simple.
2019-2-6
Wanbli
Flight distance : 3848497 ft
Jaw787 Posted at 2019-2-6 17:55
So sorry, but that is NOT true, the AC SN is not available in the Android app, is it in the ios app?EDIT: No, it is NOT in the ios app either.
Can anyone PLEASE tell me if the Serial Number can be found in any place OTHER than the sticker in the battery compartment?
2020-8-3
horse1957
where do i find the serial number dji mavic 3 pro
2021-11-25
djiuser_w3BnhI9z1t99
El Salvador
Cual es el n/s del Mavic pro
2022-4-12
