Firmware upgrade errors every time with error code 0003
8844 6 2017-7-7
Numptee Nuts
Flight distance : 144 ft
Hi
Im trying to upgrade the firmare to my p4. using assistant 2.
It downloads the firmware and I get the error code 0003 everytime (screenshot provided)
Any ideas ? Ive restarted , factory resets - no joy
Thanks
Tony
file
file
2017-7-7
fans46dfe693
Flight distance : 3022 ft
I got the same error
2017-7-7
racovejp
Flight distance : 46729 ft
Yep me too...I retried until it started and then seemed to work..PS. It did do an update to the assistant as part of the process.
2017-7-7
Aardvark
Flight distance : 384432 ft
You using latest version of DJI Assistant 2 ?
http://www.dji.com/phantom-4/info#downloads
2017-7-7
Numptee Nuts
Success. finally got it to update. I tried another pc and it worked straight away !!!!
2017-7-7
flyr
Flight distance : 23550 ft
I uninstalled four different DJI applications from my PC - two apps and two drivers.  I then installed the latest DJI assistant from dji.com/phantom-4/info#downloads (thanks Aardvark) and was able to install latest firmware to my craft.  This would explain why Numptee Nuts was able to do it on a different machine - probably a clean install of DJI software.  Hope that helps someone, somewhere
2017-10-17
Gilad3
Flight distance : 45469 ft
Israel
SOLVED!!!!
I Saw this on someone's else post and i can verify this worked for me.
You have to use an IPHONE. I used IPHONE X, the other guy used IPHONE7 PLUS.  (6 will not work)
You just update using the DJI GO 4. (note: on iphone DJI GO and DJI GO4 are different)
whenever the percentage seems stuck, or slowed - PRESS the video shoot button - a lot of clicks untill it wil continue. (it takes time. if its not failing - its working)
this is how you get to 100% and update completes.
if this wont work for the first time, try again!  i succeded on 3rd try.
Enjoy
2018-1-29
