rickysuperdog
Flight distance : 929429 ft
What casuing the " sudden interruption of the data". My Spark was powered off itself during flight of couse causing "sudden interruption of the data"
No further flight data and cannot take analysis means that it was a normal crash and I'm lying to you !?
Why i have to claim the refresh for the Spark issues. DJI choosing not to facing the serious issues and I felt shock !
Hello, I use your mailbox to find your case, the relevant colleagues have contacted you to tell and explain your case as follows:
1, has been viewed to export all the flight control data: fly82 to fly92, did not find the frying machine and the sudden interruption of the data.
2, synchronized APP account in the 2017-07-01 that day there are 7, of which 6 records are normal decline, which flight records: 2017-07-01 16:03 (GMT + 8) appears to record the situation:
2.1 environmental satellite signal is poor, after the aircraft took off in the visual mode, the aircraft control effect is normal;
2.2t = 00: 16s, h = 0m, flight records off, can not confirm the aircraft follow-up flight;
Conclusion: There is no frying data, according to the above flight records can not confirm the follow-up flight of the aircraft, can not be analyzed.
Conclusion: No frying data, according to the flight records can not confirm the follow-up flight of the aircraft, can not be analyzed, it is recommended to follow the policy.
