KedDK
Flight distance : 1133038 ft
Denmark
DJI Diana Posted at 2017-10-12 02:26
Susan is trying to help, if you couldn't provide the details of your issue, how could she help you out? For the video, you can upload it to the Youtube or Dropbox, then post a link here. As Susan told you before, The P4 is different from the P4P, you should provide a specific video of your issue.
I am (unfortunately) a DJI customer, not a Google or Dropbox customer, if you need a video uploaded showing the very same symptoms as other with issues after the 01.04.0602 update for the P4P then you must provide the platform to upload what you need.
Still i can't see no reason to make a video in the first place, plenty of those and as stated by Thor, the issue is the same so just have your engineers build a firmware that correct the issues again.
It was working just fine as it was bought, it became a PoC after the update that promised that if i was not satisfied i could downgrade again, i am not at all sitified, i can not downgrade to what ever was flashed to it when i bought it.
It should be no big problem for your engineers to make it work again as i suppose they know the code as it was before 01.04.0602, but if the internal code revision is as far out as the release notes indicate, i can see that DJI have a big problem to solve! |
