ZFK_Visuals
Hey Guys,
Just looking for some input/wisdom. I was flying my Phantom 3 over Lake Ontario about 5 days ago and crashed into a tree filming someone flyboarding. The drone dropped into the water and I had to grab it out, it spent probably 5 minutes in the water. I blow dried it, let it sit in the sun to remove the small amount of condensation in the camera and for the remainder of the time it has been buried in rice in it's box in my cool basement. I have been feeling pretty optimistic that the drone would live again as there was no mechanical damage, only water damage. I know obviously the battery used at the time in the drone is a write-off and not safe to use again so I just pulled the drone out today to see if it would start up without the props with the spare battery I have. So after throwing the battery in and starting up the drone has no power and the battery just sits there flashing LED 1 (light furthest from red light) with what appears to be no power to the rest of the body of the drone. Upon trying to charge the spare battery it does the same thing on the charger, allowing all lights to flash in sync as if it's charging twice and then going back to flashing LED 1. This has me wondering if it's a battery problem and not the drone itself. I checked the manual for the LED codes and there's nothing pertaining to LED 1 flashing besides very low battery - however you'd think the battery would be trying to charge at that point? If someone could further educate me on whether or not the battery is toast or not that would be great thanks, as I've previously had batteries die for no reason and have had to send them back.
