Lucas775
Flight distance : 15365571 ft
DroneFlying Posted at 2017-7-9 08:41
By any chance is yours an older Mavic? Some of them had a problem with a noisy rear compass that occurs when there's a lot of current (e.g., in sport mode), and I believe the message just means that the aircraft detected a (probably rear) compass problem and switched to the other one (the Mavic has two). Assuming that's the problem then you can choose to just ignore the message, fly in a way that uses less current, or you can arrange to have the wires twisted that'll reduce the compass noise as described in this thread.
Indeed mine is what I would call one of the first ones (early december), as long as it flies well I would leave it alone for now and maybe do the mod later on.
Thanks, |
