Having serious issues with palm control
1631 7 2017-7-8
SpocketNZ
New Zealand
Hi all Spark owners.
Since I got my Spark I've not been able to get it to recognise my palm to move it around. I have no problems launching, it recognises my face and takes off almost instantly. But as soon as I step back and raise my hand up, nothing. The front lights flash yellow for a few seconds, then back to red every time.
I've tried in many different lighting conditions (even though I can see myself perfectly on the app, and yes I'm in gesture mode), holding my palm in front of my face, away from my face, left hand, right hand, going as close as 20cm, and as far as 5m, but always red lights.
I can get the "away and follow" and even the "beckon" to work about 50% of the time, it doesn't seem to mind my waving hand, but palm piloting never seems to work. I could count on one hand the number of times those front LEDs turned green.
Does anyone have any tips, or is anyone else experiencing this issue? Any help is appreciated!
2017-7-8
Dirk52
Flight distance : 232995 ft
You have to hold your hand about 70cm in front of the spark. Open hand, fingers together.
Should work with no problems.
2017-7-8
Monochrome
Flight distance : 12710 ft
I have the same problem. Just watched some DJI tutorial which says that very bright light [sun? huh?] and some other things can cause problems. Some people just do not have these problems from what I've seen which led me to believe that maybe not all drones are made equal.
2017-7-9
Sparky Tim
Flight distance : 442011 ft
This sounds like the experience I have had with gesture controls. Have had them work a few times. But mostly fail.
2017-7-9
Szwedu
Flight distance : 378114 ft
Poland
what i can add, make sure you have your sennsors clean and have the sun in your face. i have problems sometimes but overall i am happy.
2017-7-9
evilsoya
I had the same issue. I sent my Spark back for repair. Thankfully the repair process was fairly fast and nowhere near what I've read about DJI Repair service on this forum (it is much faster than I expected it to be).
Here is my post:
https://forum.dji.com/thread-101911-1-1.html
2017-7-9
Ozone
If you hold your hand at about 70 degrees instead of 90 degrees difference is like night and day
2017-7-9
SpocketNZ
New Zealand
Ozone Posted at 2017-7-9 14:03
This is what I was hoping for! Since posting I've gone over a few Youtube videos and have kind of noticed that most people are pretty lazy with their hands. I've been holding my palm very straight up flat facing the camera, maybe I just need to chill it out a little.
Gives me hope how you say the difference is so noticeable! Will give this a try ASAP, thanks Ozone.
2017-7-9
