Hi there, just to verify, are you indicating the slight up and down movements in the video? Was it the windy environment where you were flying? Please try to calibrate the gimbal and IMU, check if the gimbal are mounted properly and test again, you can hover the drone in a place and see if the same case appears. Please keep us updated if the problem persists, thank you.
