fansa7dc5944
Flight distance : 50988 ft
Thailand
The event of compass error mid-flight is rare. Unless you fly into highly electromagnetic interference source like high-voltage transmission line, power grid, huge structure of ferro-magnetic, radio/mobile station that will be the case of compass error, otherwise the electronic compass itself is malfunction mid-flight which is rare. Launching from non-magnetic surface boat should not be problem. Interference from generator installed should not be problem also because the chassis itsself enclose the electro-magnetic inside or the ship navigation system will fail. You will know the compass error at the initialization. If encountered, try move the aircraft higher or away. When launched in the air, the interference is no longer effect. |
