Cabralkev
Flight distance : 1997861 ft
DJI Mindy Posted at 2017-7-19 01:22
Thanks for your updating. we are very sorry about what happened and the troubles caused to you, but the case is the very first one to us worldwide. We will do our best to locate what the problem is and keep you updated. Appreciate your patience.
It's nothing serious, doesn't danger my Inspire 1 from flying. It's just a bug I found within the DJI Go software. I've tried Litchi and the symptoms are there, but not as bad as the DJI Go app. With Litchi open, the gimbal doesn't go limp and then suddenly wake up and rotate. Instead, it stops slightly to the right like it did with the DJI Go app, but this time it corrects itself and faces forward. The DJI Go app makes the gimbal go limp, I am not sure why.
It's not the end of the world though. I just turn on my remote, then Inspire 1 and wait for the Inspire 1 gimbal to finish rotating. After it's done, I then turn on the DJI Go app. No problems. However, it is annoying to do it this way. So please try and fix this.
Thank you |
