hallmark007
Flight distance : 9827923 ft
eYeSkYeYe Posted at 2018-3-29 01:53
Actually.... it's design flaw in Spark, having cheapest possible magnetometer on the market. Note it's MEMS device and the Spark one is the first one I've ever seen that can be disrupted by inertia, not only EM/ferro interference. Either that or sub par coding like not syncing gsp vs. magnetometer (compass) readings. Checking it or not, will make 0 difference on the outcome. If something is really wrong initially, app should throw an error, not that pilot should actively look at his crystal orb and predict what might happen.
So it’s a flaw with spark that it has the cheapest magnetometers , maybe dji’s cheapest drone should have the same magnetometers as the Matrice 210 , that would make sense NOT, what your saying is just clap trap, you said you could create this at anytime but we have yet to see you do it, and it’s fair to say we see very little of it happening around here anymore, surely if there was a fault because of magnetometers every spark would be dropping out of the sky. Or where the cheap magnetometers only reserved for some sparks, Ridiculous..... |
