Skywolf007
Flight distance : 2758875 ft
Slovakia
From my experience, the Inspire will maintain its height, until it reaches landing poing - RTH point. I tried RTH functions a few times, but I don't use it.
About the 20 meters... In most cases its enough, but you should set it dynamically according to your situation. I would recommend to set it a few meters higher than anything in your flyzone, so in case RTH is engaged it will not collide with on the way back . I have 25m set, but in some cases I do set 50-100 meters too.
Also note - the height is calculated based on the takeoff point. |
