boogieman77.gma
Flight distance : 5611893 ft
I will make the upgrading process simple. Format the SD card. Do a clean install of the v.XX bin file. Insert the SD card into the camera. Do not turn the Tx on, do not start the App. Turn on the Inspire and listen to the beeps da da da da da(4times) that the camera produces. When it consistently beeps dah, dah-dah. It is done and you can turn the Inspire off. Remove the SD card and read the txt file. It should say success or cancel. Both indicate that you have completed the upgrade. Now to the Tx. Format a USB drive and install the v.17 bin file. Insert the USB drive in the USB port on the Tx and then power the Tx. After a few minutes it will begin to beep. When the beeps stop and the led turns green you are done. You can power down the Tx and remove the USB drive. I would check the txt file on the root directory just to confirm success. That completes the upgrade process. Power the Tx, then the App and then the Inspire.
If the Tx and the Inspire are not bound you can go into the App and click on bind the Tx. Make sure that you press the small button on the Inspire so the Rx led is blinking red.
The small bind button?
When looking a the craft from behind on the right hand side. You will see the Rx led. To the right of that is a small indentation that has the switch. Press it with a paper clip or other small device. The led will pulsate red. Then go to the App and bind.
Turn the tx on and connect to the App. Start the Inspire you will have a fast yellow flashing. From the back of the craft, on the right hand side you will see a red led. Next to that led is a indentation that is the binding switch. Push that with a paper clip or similar device and the led will blink red. Go into the App under the Tx tab and click bind. You should be done. Or you can reference the manual
In the manual page 32 |
