RTH Altitude- Meters or Feet
1719 6 2017-7-12
Rixxie33
I am in biginer mode- Changed setting to feet- So 98 feet both up and out- thats good-
BUT- the RTH appears to be still in metric number- is ther no way to change the RTH to feet-
I cant find a way- or will it only change to feet when off beginer mode?
2017-7-12
Bekaru Tree
Flight distance : 15513100 ft
South Africa
Beginner or any other mode will have nothing to do with it - some times some of us have found that we need to put the information in more than once _ weird i know - but for example my yaw settings i had to redo quite a few times before it stuck in the app - try set yr settings again to ft and see what happens.
2017-7-12
DroneFlying
Flight distance : 10774613 ft
No, there's no way to change it to feet; you'll just have to do the multiply-by-three thing to get a rough estimate of what it represents in feet.
2017-7-12
Tealk
Flight distance : 479613 ft
Romania
recheck that setting
2017-7-12
Car147
Flight distance : 180351 ft
Tried that myself as I use imperial settings on mine, yet RTH alt remains metric. No big deal, but just not possible for some reason.
2017-7-12
CharlieFliesDro
Flight distance : 36148 ft
Setting are in Metrics   (Built in China) Just time 3...... 50 meters 150 ft Roughly
Please don't Panic when you push the RTH button while flying at say 90ft and Notice Mavic pop up to 150ft while returning home
.........and in the controller setting (RC)  the CSC setting (pull both stick downward shuts off all motors)
should be set in an" Emergence condition" NOT " Any time"
also Controller (RC) Loss of signal .. you'll want that in" RTH" not" Hover" or "Landing"
Flying over Water.? Below 60ft Turn off your DPS (downward position sensor)
And Never Ever Try to Fly with less then 20% battery Life
................................mytwocents.......................C
2017-7-12
Rixxie33
Tealk Posted at 2017-7-12 08:39
http://fromwhereidrone.com/wp-content/uploads/2016/12/General-Settings-DJI-Go-App-Drone-1024x576.jpg[/img]
why cant I find that measurement unit again- it has disappeared?
2017-7-12
