Goof
Flight distance : 666483 ft
You really need a hotter iron for starters.
1. the solder points on the ESCs are quite large,
2. you're soldering two strands at once to each point,
3. the wires are solid core field windings wound straight around the stator. The 'motors' on each arm aren't really a full motor, they NEED the ESCs to generate pulses to the windings to get the rotor spinning.
All this adds up to make one GIANT copper heatsink sapping the life out of that poor iron. The ESCs can take a lot of abuse, you've probably not damaged them yet but at the end of the day, it's not great for their life expectancy. 50-70W is more like it, better to have to rush with a hotter iron then slowly heat up the entire ESC board waiting for something to melt, then risking a cold joint anyway.
At $30 each, you're waaaaay better off ordering new motors and just soldering them straight in. There are 12 joining tasks to do if you try and cut & shut the old wires, 24 if it turns out they're not long enough and you have to add wire. Any one of those fails and you heavily impair, if not lose a motor altogether, potentially dropping the expensive aircraft out of the sky. New motors come with the field wires pre-tinned and ready to solder straight in.
After all that you can rule out the motors. Check all other ribbon cables running around the bird, often they can have tiny cuts in them from hitting sharp edges that can escape first notice. Ensure there's no corrosion or other contamination on the gold contact surfaces. Avoid touching said contact surfaces with your fingers, use tweezers to handle the ribbon cables if you have them.
Dunno what the pipipipipip noise is but I've heard it on my birds. Kinda sounds like a very faint version of one of those diaphragm aquarium air pumps?
For reference, this is what a broken ribbon looks like, very easy to miss:
Also not all the dirt and fingerprints on it from handling it a few times. Not at all good to get that stuff on the contacts.... |
