Active Track Top Speed
736 2 2017-7-13
1K2GODrone
Flight distance : 833990 ft
All. I know I've seen some discussion but wondering if there is any solid advice for active tracking....a little faster.
I seem limited to about 20mpj and that is dependent on the lock. I practice on cars leaving my neighborhood and for no obvious reason, I get different speeds.
I'd like closer follows at higher speeds for cycling footage. Advice? Any third party apps like Litchi help this??
Thanks!
2017-7-13
ars.fabula
Flight distance : 706234 ft
Switzerland
I've been able to track a motorbike using AT-Profile mode at 60kph (about 37mph).
Make sure that you have at least FW 1.03.0600 and DJI GO V4.05 . DJI made some AT speed improvements around that time.
The faster the car / bike the further away you have to be , otherwise it will quickly go out of the frame.
Lots of space and no trees / poles / etc.
Ask your subjet / driver to start slowly and pick-up spead gradually and to avoid sharp turns.
2017-7-13
1K2GODrone
Seems dependent on that Lock! Thanks for responding.
2017-7-13
