fans987d278a
Flight distance : 124180 ft
Fly Dawg Posted at 2017-7-13 08:45
You will need a tablet with Wi Fi. Not for flying but to cache the local maps before you fly. I would also
recommend a Tablet with GPS. The reason for the black map screen is for just that reason. No Wifi,
no maps unless they are cached first.
You can use Litchi, design your mission at home on your tablet, then cache the maps you designed your mission on, you know how to cache maps? Just scroll around the area, go in & out on map & that's it.
Fire up your monitor/tablet & mission you set up will automaticly download to the Litchi app in waypoints.
Now its cached on your tablet, go to your place your flying, get your bird in the air, in litchi waypoints, your mission you set up at home will show up, hit it, Litchi, will show you a summary of # of waypoints, alltitude, etc , if your happy with all your settings hit GO & in seconds the mission will upload to your bird & off she goes, You can switch between map view, to see how mission is going, to camera view.
Also, Go on u-tube, look up waypoint missions using Litchi & there are many examples or How to's better than my quick explanation.
Great thing with litchi, even if you loose connection to your bird, it will still fly the complete mission as its downloaded to your drone.
Do make sure you have placed your last waypoint close to you so you can see your bird at last waypoint
have fun! |
