mahyem
Mauritius
Hi All,
This is the first time I'm updating my Phantom 3 Pro with the latest firmware 1.11.0020 but it is failing each time.
Below is the result from the result file:
Delete history success.
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.11.0020.bin
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
And now the log file from the hidden file:
[00015783]Delete history success.
[00016071]========== remo-con disconnect. boot(15) ============
[00016158]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x90ce5ef4].
[00016239]Packet upgrade start...
[00016323]Packet checking...
[00016403]Packet vlink 01.01.0000 <-> 01.01.0000.
[00016481]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 1).
[00016573]Done.
[00016651]Version checking[1]...
[00029241][03 05][00] device not detected.
[00041820][03 06][00] device not detected.
[00041912][04 00][00] v1.48.0.0 -> v1.38.0.0
[00042013][09 00][00] v0.0.0.0 -> v1.7.0.3 need upgrade.
[00054602][11 00][00] device not detected.
[00067182][12 00][00] device not detected.
[00079763][12 01][00] device not detected.
[00092341][12 02][00] device not detected.
[00104921][12 03][00] device not detected.
[00117501][15 00][00] device not detected.
[00130083][17 00][00] device not detected.
[00142663][17 01][00] device not detected.
[00155245][19 00][00] device not detected.
[00155323][01 00][00] v1.32.5432 -> v1.15.3056 need upgrade
[00155414][01 01][00] v1.32.5432 -> v1.15.3056 need upgrade
[00167992][08 00][00] device not detected.
[00168073]Done.
[00170150]Waiting for user confirm...
[00180229]Timeout, start upgrade automatically.
[00180392]Firmware upgrading[1]...
[00180585][01 01] Firmware upgrade start...
[00210869][01 01] Firmware upgrade finished successfully.
[00210973][09 00] Firmware upgrade start...
[00261404][09 00] Firmware upgrade finished successfully.
[00261488]Done.
[00261570]Version checking[2]...
[00261708][03 05][00] v34.2.0.9 -> v34.2.0.9
[00261828][03 06][00] v2.4.20.50 -> v2.2.6.8 need upgrade.
[00261914][04 00][00] v1.48.0.0 -> v1.38.0.0
[00262012][09 00][05] v1.7.0.3 -> v1.7.0.3
[00262169][11 00][00] v1.8.0.0 -> v1.6.0.0
[00262298][12 00][00] v1.12.0.0 -> v1.8.0.0
[00262442][12 01][00] v1.12.0.0 -> v1.8.0.0
[00262581][12 02][00] v1.12.0.0 -> v1.8.0.0
[00262717][12 03][00] v1.12.0.0 -> v1.8.0.0
[00275299][15 00][00] device not detected.
[00275514][17 00][00] v1.1.1.7 -> v1.1.1.6 need upgrade.
[00275683][17 01][00] v1.0.2.7 -> v1.0.2.5 need upgrade.
[00275793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00275873][01 00][00] v1.32.5432 -> v1.15.3056 need upgrade
[00275964][01 01][05] v1.15.3056 -> v1.15.3056
[00288544][08 00][00] device not detected.
[00288623]Done.
[00288703]Firmware upgrading[2]...
[00288808][17 00] Firmware upgrade start...
[00367959][17 00] Firmware upgrade finished successfully.
[00368059][17 01] Firmware upgrade start...
[00427743][17 01] Firmware upgrade finished successfully.
[00428013][03 06] Firmware upgrade start...
[00750209][03 06] Firmware upgrade finished successfully.
[00750295]Done.
[00750377]Version checking[3]...
[00750499][03 05][00] v34.2.0.9 -> v34.2.0.9
[00750620][03 06][05] v2.2.6.8 -> v2.2.6.8
[00750711][04 00][00] v1.48.0.0 -> v1.38.0.0 need upgrade.
[00750825][09 00][05] v1.7.0.3 -> v1.7.0.3
[00750980][11 00][00] v1.8.0.0 -> v1.6.0.0
[00751110][12 00][00] v1.12.0.0 -> v1.8.0.0
[00751275][12 01][00] v1.12.0.0 -> v1.8.0.0
[00751409][12 02][00] v1.12.0.0 -> v1.8.0.0
[00751535][12 03][00] v1.12.0.0 -> v1.8.0.0
[00764114][15 00][00] device not detected.
[00764270][17 00][05] v1.1.1.6 -> v1.1.1.6
[00764450][17 01][05] v1.0.2.5 -> v1.0.2.5
[00764545][19 00][00] v1.0.8.96 -> v1.0.8.96
[00764624][01 00][00] v1.32.5432 -> v1.15.3056 need upgrade
[00764705][01 01][05] v1.15.3056 -> v1.15.3056
[00777293][08 00][00] device not detected.
[00777375]Done.
[00777457]Firmware upgrading[3]...
[00777568][04 00] Firmware upgrade start...
[00834674][04 00] Firmware upgrade finished successfully.
[00834750]Done.
[00834828]Version checking[4]...
[00834953][03 05][00] v34.2.0.9 -> v34.2.0.9
[00835066][03 06][05] v2.2.6.8 -> v2.2.6.8
[00835180][04 00][05] v1.38.0.0 -> v1.38.0.0
[00835270][09 00][05] v1.7.0.3 -> v1.7.0.3
[00835451][11 00][00] v1.8.0.0 -> v1.6.0.0
[00835575][12 00][00] v1.12.0.0 -> v1.8.0.0
[00835700][12 01][00] v1.12.0.0 -> v1.8.0.0
[00835959][12 02][00] v1.12.0.0 -> v1.8.0.0
[00836080][12 03][00] v1.12.0.0 -> v1.8.0.0
[00848665][15 00][00] device not detected.
[00848797][17 00][05] v1.1.1.6 -> v1.1.1.6
[00848957][17 01][05] v1.0.2.5 -> v1.0.2.5
[00849051][19 00][00] v1.0.8.96 -> v1.0.8.96
[00849130][01 00][00] v1.32.5432 -> v1.15.3056 need upgrade
[00849215][01 01][05] v1.15.3056 -> v1.15.3056
[00861798][08 00][00] device not detected.
[00861874]Packet upgrade failed at version checking.
[00015701]========== remo-con disconnect. boot(15) ============
[00015780]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce5ef4].
[00015860]Packet upgrade start...
[00015949]Packet checking...
[00016028]Packet vlink 01.03.0020 <-> 01.01.0009.
[00016109]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016189]Done.
[00016268]Version checking[1]...
[00016402][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016502][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00016594][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00016692][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016842][11 00][00] v1.8.0.0 -> v1.7.0.0
[00016957][12 00][00] v1.12.0.0 -> v1.8.0.0
[00017076][12 01][00] v1.12.0.0 -> v1.8.0.0
[00017202][12 02][00] v1.12.0.0 -> v1.8.0.0
[00017314][12 03][00] v1.12.0.0 -> v1.8.0.0
[00029895][15 00][00] device not detected.
[00030039][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00030194][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00030286][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030367][01 00][00] v1.32.5432 -> v1.23.3419
[00030447][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00043027][08 00][00] device not detected.
[00043104]Done.
[00045185]Waiting for user confirm...
[00055263]Timeout, start upgrade automatically.
[00055427]Firmware upgrading[1]...
[00055614][01 01] Firmware upgrade start...
[00085908][01 01] Firmware upgrade finished successfully.
[00086009][17 00] Firmware upgrade start...
[00169423][17 00] Firmware upgrade finished successfully.
[00169588][17 01] Firmware upgrade start...
[00231019][17 01] Firmware upgrade finished successfully.
[00231277][03 06] Firmware upgrade start...
[00565999][03 06] Firmware upgrade finished successfully.
[00566108][04 00] Firmware upgrade start...
[00623605][04 00] Firmware upgrade finished successfully.
[00623685]Done.
[00623765]Version checking[2]...
[00623868][03 05][00] v34.2.0.9 -> v34.2.0.9
[00623992][03 06][05] v2.2.6.19 -> v2.2.6.19
[00624081][04 00][05] v1.40.0.0 -> v1.40.0.0
[00624181][09 00][00] v1.7.0.3 -> v1.7.0.3
[00624352][11 00][00] v1.8.0.0 -> v1.7.0.0
[00624481][12 00][00] v1.12.0.0 -> v1.8.0.0
[00624626][12 01][00] v1.12.0.0 -> v1.8.0.0
[00624750][12 02][00] v1.12.0.0 -> v1.8.0.0
[00624907][12 03][00] v1.12.0.0 -> v1.8.0.0
[00637487][15 00][00] device not detected.
[00637616][17 00][05] v1.1.1.7 -> v1.1.1.7
[00637781][17 01][05] v1.0.2.7 -> v1.0.2.7
[00637877][19 00][00] v1.0.8.96 -> v1.0.8.96
[00637966][01 00][00] v1.32.5432 -> v1.23.3419
[00638044][01 01][05] v1.23.3419 -> v1.23.3419
[00014673]========== remo-con disconnect. boot(15) ============
[00014751]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce5ef4].
[00014836]Packet upgrade start...
[00014917]Packet checking...
[00014998]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015080]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015159]Done.
[00015244]Version checking[1]...
[00015357][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015476][03 06][00] v2.2.6.19 -> v2.2.6.19
[00015561][04 00][00] v1.40.0.0 -> v1.40.0.0
[00015676][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015842][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015971][12 00][00] v1.12.0.0 -> v1.8.0.0
[00016106][12 01][00] v1.12.0.0 -> v1.8.0.0
[00016231][12 02][00] v1.12.0.0 -> v1.8.0.0
[00016377][12 03][00] v1.12.0.0 -> v1.8.0.0
[00028956][15 00][00] device not detected.
[00029109][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029265][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029362][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029562][01 00][00] v1.32.5432 -> v1.23.3419
[00029643][01 01][00] v1.23.3419 -> v1.23.3419
[00042228][08 00][00] device not detected.
[00042308]Packet upgrade failed at version checking.
[00015223]========== remo-con disconnect. boot(15) ============
[00015304]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce5ef4].
[00015383]Packet upgrade start...
[00015471]Packet checking...
[00015568]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015654]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015731]Done.
[00015810]Version checking[1]...
[00015928][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016029][03 06][00] v2.2.6.19 -> v2.2.6.19
[00016123][04 00][00] v1.40.0.0 -> v1.40.0.0
[00016213][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016390][11 00][00] v1.8.0.0 -> v1.7.0.0
[00016515][12 00][00] v1.12.0.0 -> v1.8.0.0
[00016641][12 01][00] v1.12.0.0 -> v1.8.0.0
[00016765][12 02][00] v1.12.0.0 -> v1.8.0.0
[00016899][12 03][00] v1.12.0.0 -> v1.8.0.0
[00029487][15 00][00] device not detected.
[00029616][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029777][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029873][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029958][01 00][00] v1.32.5432 -> v1.23.3419
[00030038][01 01][00] v1.23.3419 -> v1.23.3419
[00042629][08 00][00] device not detected.
[00042709]Packet upgrade failed at version checking.
[00014668]========== remo-con disconnect. boot(15) ============
[00014744]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00014828]Packet upgrade start...
[00014916]Packet checking...
[00014994]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015075]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015153]Done.
[00015242]Version checking[1]...
[00015334][03 06][00] v2.2.6.19 -> v2.4.20.50 need upgrade.
[00015440][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015522][04 00][00] v1.40.0.0 -> v1.48.0.0 need upgrade.
[00015679][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015815][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015969][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016093][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016214][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016349][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016474][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029057][15 00][00] device not detected.
[00029187][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029371][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029470][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029556][01 00][00] v1.32.5432 -> v1.32.5432
[00029637][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00042213][08 00][00] device not detected.
[00042333][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00042411]Done.
[00044492]Waiting for user confirm...
[00054570]Timeout, start upgrade automatically.
[00054734]Firmware upgrading[1]...
[00054917][01 01] Firmware upgrade start...
[00085202][01 01] Firmware upgrade finished successfully.
[00085505][03 06] Firmware upgrade start...
[00462459][03 06] Firmware upgrade finished successfully.
[00462563][09 00] Firmware upgrade start...
[00514776][09 00] Firmware upgrade finished successfully.
[00514883][04 00] Firmware upgrade start...
[00573010][04 00] Firmware upgrade finished successfully.
[00573097]Done.
[00573177]Version checking[2]...
[00573330][03 06][05] v2.4.20.50 -> v2.4.20.50
[00573442][03 05][00] v34.2.0.9 -> v34.2.0.9
[00573535][04 00][05] v1.48.0.0 -> v1.48.0.0
[00573708][11 00][00] v1.8.0.0 -> v1.8.0.0
[00573888][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00573976][11 01][00] v1.8.0.0 -> v2.0.0.33
[00574117][12 00][00] v1.12.0.0 -> v1.12.0.0
[00574251][12 01][00] v1.12.0.0 -> v1.12.0.0
[00574408][12 02][00] v1.12.0.0 -> v1.12.0.0
[00574565][12 03][00] v1.12.0.0 -> v1.12.0.0
[00587145][15 00][00] device not detected.
[00587269][17 00][00] v1.1.1.7 -> v1.1.1.7
[00587439][17 01][00] v1.0.2.7 -> v1.0.2.7
[00587545][19 00][00] v1.0.8.96 -> v1.0.8.96
[00587623][01 00][00] v1.32.5432 -> v1.32.5432
[00587707][01 01][05] v1.32.5432 -> v1.32.5432
[00600421][08 00][00] device not detected.
[00600537][09 00][05] v4.1.0.0 -> v4.1.0.0
[00600616]Packet upgrade failed at version checking.
[00014800]========== remo-con disconnect. boot(15) ============
[00014884]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00014970]Packet upgrade start...
[00015054]Packet checking...
[00015138]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015218]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015297]Done.
[00015384]Version checking[1]...
[00015643][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015768][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015855][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016022][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016182][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016261][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016410][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016538][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016670][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016795][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029382][15 00][00] device not detected.
[00029511][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029687][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029787][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029867][01 00][00] v1.32.5432 -> v1.32.5432
[00029949][01 01][00] v1.32.5432 -> v1.32.5432
[00042531][08 00][00] device not detected.
[00042647][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042729]Packet upgrade failed at version checking.
[00015438]========== remo-con disconnect. boot(15) ============
[00015517]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00015604]Packet upgrade start...
[00015692]Packet checking...
[00015772]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015853]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015933]Done.
[00016022]Version checking[1]...
[00016146][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016282][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016366][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016547][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016781][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016860][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016992][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017146][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017305][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017436][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030017][15 00][00] device not detected.
[00030150][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030348][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030464][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030546][01 00][00] v1.32.5432 -> v1.32.5432
[00030630][01 01][00] v1.32.5432 -> v1.32.5432
[00043228][08 00][00] device not detected.
[00043331][09 00][00] v4.1.0.0 -> v4.1.0.0
[00043409]Packet upgrade failed at version checking.
[00014715]========== remo-con disconnect. boot(15) ============
[00014802]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00014889]Packet upgrade start...
[00014977]Packet checking...
[00015063]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015143]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015230]Done.
[00015315]Version checking[1]...
[00015448][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015582][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015683][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015841][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016101][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016177][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016329][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016469][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016621][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016781][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029365][15 00][00] device not detected.
[00029798][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029883][01 00][00] v1.32.5432 -> v1.32.5432
[00029972][01 01][00] v1.32.5432 -> v1.32.5432
[00042567][08 00][00] device not detected.
[00042679][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042761]Packet upgrade failed at version checking.
[00014877]========== remo-con disconnect. boot(15) ============
[00014957]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00015044]Packet upgrade start...
[00015130]Packet checking...
[00015212]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015297]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015377]Done.
[00015465]Version checking[1]...
[00015580][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015700][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015787][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015965][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016120][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016201][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016335][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016465][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016593][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016728][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029311][15 00][00] device not detected.
[00029429][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029611][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029725][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029807][01 00][00] v1.32.5432 -> v1.32.5432
[00029891][01 01][00] v1.32.5432 -> v1.32.5432
[00042471][08 00][00] device not detected.
[00042585][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042664]Packet upgrade failed at version checking.
[00014888]========== remo-con disconnect. boot(15) ============
[00014974]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x90ce5ef4].
[00015055]Packet upgrade start...
[00015143]Packet checking...
[00015224]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015305]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015385]Done.
[00015477]Version checking[1]...
[00015608][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015748][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015843][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016108][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016275][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016353][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016572][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016724][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016857][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016998][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029582][15 00][00] device not detected.
[00029721][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029898][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030005][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030088][01 00][00] v1.32.5432 -> v1.32.5432
[00030175][01 01][00] v1.32.5432 -> v1.32.5432
[00042762][08 00][00] device not detected.
[00042865][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042945]Packet upgrade failed at version checking.
Any help will be appreciated.
Thank you. |
