Wolfman
Flight distance : 405659 ft
Thanks for your reply Tahoe. I will get this info to you tomorrow. The case has been opened in China via my place of purchase. They also have the flight logs. I am yet to hear anything though
As for your comments, can you assist in clearing these things up:
Yes, maybe I should not have taken off without GPS BUT the craft is designed to do this as per indoor flights.
IMU calibration performed approx 4 days prior.
I presumed that without GPS, manually setting home point would do nothing. SO when I lost RC signal, where would the aircraft have been going to?
What is the fail safe procedure for the aircraft in these specific circumstances, I would have thought it would go in to a hover then land
If it was in RTH mode, can you confirm that the aircraft is supposed to climb vertically to its pre set RTH altitude then proceed. Mine took of rapidly at 30 to 45 degrees whilst climbing. |
