**p3s Range Poll**
1194 35 2017-7-16 01:50:22
ysmith
Flight distance : 171430
New Zealand
Just interested in the average maximum range ppl get with p3s. From our house I get no more than 400m (cause of wifi interference etc.), but yesterday out in the country I managed to fly over a 1km away before RTH kicked in (I started out with only 50% power remaining, so I could have gone a bit further if started with full battery).
PS. this poll is for phantom 3 standard's only
Cheers
Single SelectVote, Total 86 people participate in voting
Distance end of: 31 Day14 Hour50 Min
Your user group with no voting privileges
2017-7-16 01:50:22
Dirty Bird
Flight distance : 1114321
Over densely populated areas I get 2500-4000' (feet).  Flying over open water I get 5000-7000'.
2017-7-16 05:35:27
djordan2
Flight distance : 10399
The P3S is just not a range machine.  I don't know how you do it!
2017-7-16 05:47:48
tkflyfisher7
I can get up to 9,000 feet....maybe I'm cheating though....the DBS mod changed my flying life!
2017-7-16 06:52:30
blackcrusader
Flight distance : 203309
Taiwan
tkflyfisher7 Posted at 2017-7-16 06:52
I believe it was meant for people without mods.  I could do 500m - 600m without mods but I never really tried to fly longer distance until I got my Argtek Antenna  with which I have done near 15000 feet distance. I could really fly with a fully charged battery and maybe push to 16000 maybe 17000 feet distance but then you need enough power to bring the drone back to home point as well. On this flight shown below I actually did my distance then got the bird back with around 25% battery remaining so flew another short hop and landed with 15%. I use the Argtek not just for range but to keep strong signal connections when flying at over 10,000 feet altitude above the clouds using max 500m height and around 3km distance.
2017-7-16 07:46:34
Michgolden
Flight distance : 196095
I've gone out 15,327 feet. I average between 8,500-11,500 feet. I run the Argtek and the rest is stock. I don't know how but I'm not going to complain . The pic of my longest flight is post #84 under the "How good is the Argtek antenna setup P3S"
2017-7-16 07:58:20
blackcrusader
Taiwan
Michgolden Posted at 2017-7-16 07:58
Good idea to pop in a link to the thread.
http://forum.dji.com/thread-85652-1-1.html
2017-7-16 10:50:15
Michgolden
blackcrusader Posted at 2017-7-16 10:50
Thanks BC. I usually go on here through my PS4 but it's not the best for putting in links and pics ;).
2017-7-16 13:40:39
ysmith
New Zealand
blackcrusader Posted at 2017-7-16 07:46
yeah, I don't have a mod so i didnt really think of them, sorry. but i think most people with p3s have mods because as djordan2 said they aren't too flash when it comes to range, so mods are fine for this poll
2017-7-16 14:55:24
timnwcove
Flight distance : 26648
not much into the range thing......but have full 2.4 and 5.8  out to my normal 300m
2017-7-16 16:03:43
Knobbynomates
timnwcove Posted at 2017-7-16 16:03
My only mod is 'PapaTita's Software mod' and I regularly get 2 - 3000 m
2017-7-17 06:18:41
Porktree
Flight distance : 60068
I can get up to about 1.5 k - with the Argtek mod, but I've yet to fly somewhere where I'm not surrounded by trees or in a slight valley.  Yay Missouri.
2017-7-17 10:20:03
Peterx
Flight distance : 197229
my bird was 300+ meters with normal stock in 40 - 50 meters altitude. But it looks very small in that distance. But it´s enough distance for me
2017-7-18 11:40:06
tnflyer53
Flight distance : 65787
With only windsurfer and DJI go software I've had my p3s out to almost 4000ft at 350ft altitude.
2017-7-18 19:03:06
ysmith
New Zealand
tnflyer53 Posted at 2017-7-18 19:03
Not too bad! The max Iv been with just stock out-of-the-box was about 3360 ft at 950 ft altitude, pretty good I thought for stock; wonder if anyone has been further than that (with stock)?
2017-7-19 01:16:35
tnflyer53
Of course longer ranges would be nice, I would really like it if I could figure out the magnetic interferences and video that doesn't skip or lag.
2017-7-19 03:51:14
waclark
Flight distance : 8693
djordan2 Posted at 2017-7-16 05:47
There are mods that will get you more range. From what I've read the antenna mods like the ArgTek can double the range. I've also heard that using Litchi can get you extended range as well.
2017-7-19 12:03:27
Salmonslayer
Flight distance : 30546
My ArgTec have got me 1500 on my P3S ( until the recent FW update issues), Haven't got Litchi but seriously considering it. Will litchi illuminate the 30/50 range problem with dji app??
2017-7-22 09:42:07
G_Sig
Flight distance : 161617
Iceland
1000 - 2000 with standard setup. + - 3000 with mod.
2017-7-22 10:06:23
Zsolti
Flight distance : 132969
Romania
With windsurfer
2017-7-23 05:19:54
djordan2
Tonight I installed firmware V1.5.70+.  I'll fly tomorrow and see what difference it makes, if any,  in range.
Edited 7/26/2017.  Test flew to 1,200 with the ARgtk mod installed.  No good.  Will not go any farther in open desert country at 150 feet up.
2017-7-24 20:46:56
G_Sig
Iceland
Salmonslayer Posted at 2017-7-22 09:42
Litchi won't change the 30/50  as it is FW which is causing that. I have both apps and it works the same way 30m attitude 50m distance.
2017-7-26 08:18:46
Axor11
Flight distance : 134758
I get about 80/90 meters stock..and get 280meters with little copper range extender
2017-7-26 13:46:19
Scott Ferguson
Flight distance : 404887
I usually get around 4500' in any direction I go from my house sometimes a little more with everything stock. I made a homemade parabolic booster and can get an average of around 9000' with it
2017-7-26 16:13:53
timnwcove
i still only fly out to my 500m max, but using some convoluted math.........i should be able to get out to 1285m before i loose connection between the bird and controller due to trees.   according to my calculations, the bird should have strong signal until the trees interfere at 1285m.
2017-8-1 15:02:27
solentlife
Flight distance : 94150
Latvia
Out of box CE version no mods : ~300m urban  ~600m open country
ICARUS 27 mod stock antenna : ~600m urban  ~800m open country
ICARUS 27 + ARGTEK antenna : ~1000m urban  ~2300m open country
ICARUS 27 + ARGTEK antenna + double Windsurfer : ?? urban (not tested in urban area)  ~4300m open country
ICARUS 27 + ARGTEK antenna + 2W boosters : ?? urban (not tested in urbam area)  ~5000m open country
My Youtube channel "solentlifeuk" has on-board and screen videos of above for those interested in all the data - height etc.
Nigel
2017-8-1 22:18:53
bluemarley67
Flight distance : 342266
in the country i was able to get abou 2,400m from myself no boosters when i had mine it was all stock right to the T.
2017-8-8 06:30:43
DronerX
Flight distance : 102313
Before I upgraded the antennas on the RC, the max I could get was about 500m.  With the antenna upgrade, I can routinely get 1000m.
2017-8-23 11:00:02
DronerX
Knobbynomates Posted at 2017-7-17 06:18
Care to elaborate on what the mod is?
2017-8-23 11:00:48
Knobbynomates
DronerX Posted at 2017-8-23 11:00
Google is your friend - that will give you the answer and where to find it
It works well for me
Can't say any more
No unauth modification posts allowedPosts will be removed with no warning
2017-8-23 11:29:37
epicdoom0
Flight distance : 35893
no mods I got out to 2K regularly and lost signal.
Argtek mod I get out to 4300ft
DBS I've been out to 7600ft
2017-8-23 17:39:30
fans15f676e4
Flight distance : 61480
I live in an area with a lot of forest. I'm up high on top of a mountain top and I got 7400 ft. I don't normally push it . I have done it twice.
2017-8-26 08:28:03
Rabe
Flight distance : 289042
In Europe we have the CE guidelines and this reduces the transmitting power compared to the guidelines in the USA
So to achieve a range of 500 meters in Europe is really good
2017-8-27 06:56:26
Rabe
Yesterday I had perfekt conditions and I reached 800 m in 50 m altitude flying straight away from me. But  in the moment I turned the drone, the connection was lost.
I recognized this behaviour often before.  The best reception ist when the drone is facing away from me and I look at her backlights. So I can reach a distant point ant then have to trust RTH
2017-8-28 01:26:31
dayviduk
Newbee question , couldnt you just fly it backwards if you have LOS
2017-8-28 07:38:43
KEM
Flight distance : 31034
1600' out of the box. 1800' with the windsurfer and my biggest disappointment was almost 2000' with the ARGtek..
2017-8-28 15:53:27
Close
DJI RecommendsPrevious /1 Next
