Learning Litchi and a rather close call
804 3 2017-7-17
Cwood
Flight distance : 97638 ft
I had been wanting to use a local lighthouse (3.2 km away) as a POI mission subject.  I got the nerve to do it and have now run three missions with improving success....and a close call.
The challenge is that the coordinates of the lighthouse are not exactly known so I have been estimating and tweaking paths.  Only issue now is that the bird is returning in reverse :-) so I need to fix that.
Close call (if you want to avoid the long run over water skip ahead to 6 mins.
https://drive.google.com/open?id=0B6DAeLDK1iw3amhwdDhUR2NNaWs
Better orbit on this one, but I sitll need to adjust its position further.  You can't correct it properly by leaveing the POI in the wrong place and just adjusting the track because it points at the wrong spot...the birds on this island are nuts at this hour!  Looks like Jurasic Park!
https://drive.google.com/open?id=0B6DAeLDK1iw3OVRJbmxYeldIOEk
2017-7-17
wglovett
I had no idea that lighthouse was out there! lol Not sure i have the nerve to cover that much water that far from shore, good for you! The second vid had some scool skies and lighting, well done!
2017-9-15
WillBapta
You have guts flying that far out. Glad it worked out but be careful
2017-9-15
