Ipad mini 4 case and controller?
2662 11 2017-7-18
jdjeff
I was looking at some ipad mini 4 cases online (Amazon) and wondering if the mini 4 with case will still fit in the holder of the P4P controller.  Anyone using a case and if so which one?  Screen protectors too?
2017-7-18
Antonio76
Flight distance : 144403 ft
Denmark
I think a normal front cover, easily detacheable, would be much better. A full case, when the front flap is folded back, might be too thick for the holder...
2017-7-18
jdjeff
Antonio76 Posted at 2017-7-18 05:20
A "normal front cover" meaning screen protector?  I'm new to tablets, bear with me.
2017-7-18
Antonio76
Denmark
jdjeff Posted at 2017-7-18 10:28
Yes, I think it can be called a screen protector. it connects to the longer side of the tablet via magnets and detaches easily, while a case has a back where the tablet sits, and a front flap which can be folded back, and taking the tablet out of the back can be annnoying...
2017-7-18
jdjeff
When I say "case", this is what I mean.  Maybe it's called a skin, a protector, a protective case.  I'm not talking about the purse style girly case.
2017-7-18
Antonio76
Denmark
jdjeff Posted at 2017-7-18 13:21
I see what you mean… I think that is what is called a skin. So, it would depend on how thick it is, also with regard to the slot in the Phantom foam carrying box, which has a slot for an iPad Mini sized tablet…When I was talking about a case I was referring to this (Apple calls it a Smart Case). A Cover would just be something like the upper part of a Smart Case, with a thin magnetic hinge, and Apple calls it a Smart Cover. A screen protector would be one of those thin, transparent sheets of plastic that one can put on the screen to protect it from dust and scratches.
2017-7-18
DJI Thor
Flight distance : 13602 ft
The maximum for the mobile device holder is 170mm, so we recommend buying one lower than this size.
2017-7-18
Antonio76
Denmark
DJI Thor Posted at 2017-7-18 23:50
Hi DJI Thor, I just checked, and the iPad Mini 4 is 203.2 x 134.8 mm, 6.1 mm thick, previous models were 200 x 134.7 mm, 7.5 mm thick,  so they would certainly fit the holder even with a skin. On the other hand my iPad 5th gen is 200 x 169.5 mm, 7.5 mm thick, so it barely fits. The major issue for a Mini 4 with a skin would be the thickness, and how easily it would be gripped by the clamp.  Also, the slot in the Phantom styrofoam box is about 13 mm , so a skin for the mini needs to be less than 5 mm thick to be on the safe side if one wants to carry it in the box.
2017-7-19
jdjeff
Hmmm ok...I was looking at these.  And DUH!...I should just try mounting the skin I have in my hand in the photo above..  I just thought of that.
2017-7-19
DroneGuyEd
Flight distance : 1168140 ft
YES, iPad mini will fit fine in the P4 controller with case attached.  Has about 1 inch to spare vertically.
2017-7-19
jdjeff
Great...thanks.
2017-7-19
Rodger8
Flight distance : 20145135 ft
I use a mini 4 with the invisible shield screen protector. If you do that and use the Apple silicone case it will fit fine with plenty to spare.
2017-7-20
