RTH in sportmode not returning to home but landing at current spot ?
2142 10 2017-7-18
Erwin Beckers
Flight distance : 26342 ft
Question, should RTH work in sport mode ? since for me it does not ?It seems to just land on the spot it currently is instead of returning home and landing.Just had time enough to cancel it otherwise my spark would have made its first water landing :-)
2017-7-18
dronist
Sweden
It should work the same in either mode. Make sure it is far from home position when you do the rth. Also put a minimum of 60 meters for RTH.
2017-7-18
Erwin Beckers
Are you sure about this? Normally the RTH works perfectly, also when the spark is closer then 60m from home position. I had it RTH from 10m or so without any problems.
But in sport mode it simply refuses and just does a landing instead of returning
2017-7-18
hallmark007
Flight distance : 6342851 ft
Erwin Beckers Posted at 2017-7-18 19:53
It should RTH but speed will change to 10 m/s. Have you checked your settings , it could also be a case that AC doesn't think it has enough battery left to come home so lands.
You could all ways check this out by preforming RTH at 80 m normal mode and then try sport at 80m ensuring both times you have same amount of battery.
2017-7-19
Aerial Ant
Flight distance : 1249715 ft
Are you using ONLY sport mode is the first question? Now whether you are or aren't doesn't matter if you enabled "RTH at current altitude". That is one I stay far away from because if you hit RTH and are further away than 20m (over 65' 1/2 ft) it will land immediately! And I'm sure that flying in sport mode you get far rather quickly. Or you are simply hitting the land icon instead of RTH. I'm not claiming to know your exact problem but trying to shed some insight into what might be wrong.
2017-7-19
Erwin Beckers
Aerial Ant Posted at 2017-7-19 21:22
No i'm not using sport mode very often (almost never). But on this flight i wanted to have a play with just for fun. So i took off in normal mode and when the spark was at 20m height and 50m distance i switched it in sport mode and had some fun flying it around.
After a few minutes (the spark was around 200m distance) i wanted to stop and hit the RTH button.
I always use this button and it always works perfectly. But this time (while still in sport mode) it decided to land at the place it was (above water).
Luckily i could cancel the RTH procedure, then turned sport mode OFF and hit the RTH again. Flying in normal mode again , the RTH did what it should do and the spark returned home
2017-7-22
HamdiR
Flight distance : 70262 ft
Lebanon
Add to the current location St of problems
Joesec test videos showed that RTH can screw up if there is magnetic interference
2017-7-23
hallmark007
Erwin Beckers Posted at 2017-7-22 23:09
Why? Would you want to return with sport mode on, your aircraft outside 100 metres will only RTH at 10 m/s whether you have it in sport or normal. Your AC can't return at sport mode speed.
2017-7-23
hallmark007
HamdiR Posted at 2017-7-23 02:36
Of course with all dji drones if you have compass interference your aircraft will not fly correctly.
2017-7-23
jh8
Flight distance : 39659 ft
I actually used RTH this morning in Sport mode and it worked fine (in NL).
2017-7-23
Erwin Beckers
hallmark007 Posted at 2017-7-23 03:32
no particular reason, just forgot to switch sport mode off before hitting the RTH button
2017-7-23
