Shoonay
Flight distance : 591831 ft
Poland
Might be on to something here. I'm a pretty new drone user, had the Spark for 1.5 month now, used a single battery for a few weeks since I couldn't afford the Fly More Combo.
Had my share of adventures with aftermarket propellers, some rougher on the surface, some smoother, but I'm almost 100% sure the ones I have now, black with golden line at the tip, are very good and balanced.
Unfortunately I crashed them at the first flight today, from 1m above only but it let a few minor scratches on the surface
I'm almost sure it was the batteries fault, I used the very first batterie at that try, after that tried battery #2 and #3 and they very stable again.
Gave me a little heart attack, but like I said, I'm content now cause I'm almost sure it's the first batteries fault.
I think it's easiest to recognize that it fails to maintain the altitude if you quickly push it up all the way in sport mode, the battery can't handle all the drain.
Switching it back to "normal" mode or going slowly with the stick sometimes makes it stable, sometimes not... I think there's also the charger you use. Using the original USB one that came with the drone takes longer but makes the battery "charge better" if you know what I mean.
Also have an aftermarket one that can charge 3 batteries at a time much quicker, but I think it's not making a good job with my very first battery that had too many cycles already... |
