Got my Spark today
564 6 2017-7-18
Lucas775
Flight distance : 50642090 ft
Ok, I got my Spark today and I am using it with OTG cables.  I am having trust issues with this thing for now, when using OTG cables should I have my wifi off and put it on airplane mode? What happens if the wifi is on?  Hopefully this will help me with my trust issues.  By the way I am on iOS system.
Thank you,
2017-7-18
CoreyB10
Flight distance : 1665023 ft
Turn your wifi on your device off. Connect the cables and away you go. It flies fine and so far lots of us have had no issues at all. Flown mine with OTG on both Android and iPad Mini 4 with no issues.
2017-7-18
CoreyB10
Forgot to ask is it the stand alone Spark or the Fly-more combo..?? If its the stand alone you will obviously still have the distance and height restrictions in place.
2017-7-18
JaredD
Flight distance : 298957 ft
CoreyB10 Posted at 2017-7-18 21:47
What do you mean exactly Corey?
The way i read your comment, I feel you are talking about flying with vs without a Remote control, and without a remote control you cannot fliy using an OTG cable.
Or are you saying that the fly more combo has the distance and height restrictions turned off by default, and the regular spark has them on by default?
2017-7-18
CoreyB10
Sorry for the crossed wires. Refer to my initial reply Jared. Without the controller the range is much less due to the mobile device range etc.
2017-7-18
Lucas775
I have the fly more combo.   Thanks for confirming that.
2017-7-19
QuadBart
Flight distance : 256506 ft
I leave my Ipad Mini 4 just as it is.  Wifi is on. I just plug the cable in, fire up the Spark, then the remote then the Ipad.  While I've not gone further than maybe 50 meters away, everything is fine....
And thats exactly the order I have to fire it up in or the Remote doesn't talk to the Spark...
2017-7-19
