OTG connection to my phone/tablet
1105 5 2017-7-19
realstreetuk
Flight distance : 7966 ft
Hi
When I connect my OTG to my Phone or Tablet to access the 2.4ghz or 5.8ghz connection it does the job
as but although I have the connection as MTP transfer in the USB  setting it also charges my Phone or Tablet at the same time i persume from the power of the RC....
Is this normal??
Thanks
2017-7-19
DJI Thor
Flight distance : 13602 ft
Hi there, it is normal to show a charging symbol if one connects the RC to Android mobile device via OTG cable, but actually, it is not charging. If it is an iOS mobile device, the charging icon light up for a few seconds and then back to normal.
But the connection between the RC and the mobile device via OTG cable has not been fully tested, so I would suggest that you use it with caution.
2017-7-20
Lush123
Flight distance : 16627 ft
ok I will check if this is true, just got one of those usb amp dongle arrived two days ago.. my Samsung s8+ keeps going into reverse charging mode no matter what.
2017-7-26
realstreetuk
Lush123 Posted at 2017-7-26 08:31
reverse charging?
2017-7-26
Lush123
yes reverse charging,  the phone (s8)  is powerful enough to charging another device using the OTG cable...
Believe some new phone are able to do that too.
2017-7-26
realstreetuk
Lush123 Posted at 2017-7-26 08:42
oh right did not know that,
2017-7-26
