DJI Diana
Flight distance : 2408 ft
fans95c1f724 Posted at 2017-11-25 18:21
I have exactly the same problem as described on this thread. In short, after trying to update the dji mavic pro remote control firmware using the DJI GO app, the update failed, and now the RC is stuck in the "CONNECTING..." loop. When I try to upgrade it via the Assistant application on either Mac or Windows, the aplication detects the RC controller but it shows that the firmware version is v00.00.0000 and I can not update or return to factory settings. Any suggestions?
Hi, there, I've replied your another post, please refer to the routes below to find out the upgrade log, then upload it to the Dropbox or Google Drive, so I can download it for analysis, thank you in advance.
Assistant 2(Windows): C:/Users/XXXXXX/AppData/Roaming/DJI Assistant 2/upgrade_log
Assistant 2(MAC):~/Library/Application Support/DJI Assistant 2/upgrade_log
