roberteb
Flight distance : 131417 ft
R&L Aerial Posted at 2017-7-20 13:52
The iPad pro charger works better than the charger that came with the spark, it doesn't get hot like the iPhone or the OEM charger and will charge your spark in less time. More time flying, less time charging-more fun. ( there's a self proclaimed physics major that throws a bunch of fancy numbers around that are meaning less) so try the iPad pro charger, the 29 watt version, and you will be pleasantly surprised...
Before the thread derails :-)
The Ipad Pro charger isn't the charger delivered with your Ipad Pro,but need to be purchased seperate
Standard DJI (Fly Less) is 12v 1.5
Ipad Pro (29 Watt) 12v 2.4A (?), based on 14.5V - 2A apple specs
Ipad Pro seems able to have a 60% higher output.. BUT:
Charging your battery to fast can damage your battery or reduce life-time!
If you have the fly more combo, the charger hub is able to supply 12v 3.8A, but still will take approx 53 mins to charge 1 battery and 2 will take approx 55 mins..
I assume is safety measure, as theoretically one battery can be load in 27 mins
