Natesac
Flight distance : 252526 ft
If you've been piloting the Spark with the remote control, the Spark will not broadcast it's SSID. You will need to power up the Spark (leave the remote control off) then on the back of the Spark press and hold the power button until you hear two beeps. Then the Spark will be broadcasting it's SSID. You can then connect your phone to the Spark's SSID, open up DJI go4, and download the original files.
It works in a pinch if you don't have a computer around and want to edit and share from a phone/tablet.
Side note: If you follow the directions above, the next time you want to fly using your remote control, you will need to re-pair your spark to your remote control. You can do this by powering on the Spark and the Remote control. Hold the power button on the spark till it beeps once. Then pick up the remote (powered on) and hold the Pause, Fn, and right shoulder button until the controller beeps. It should re bind the controller with the spark. If you have any trouble I'm sure youtube can help |
