Spark ecs prob
881 13 2017-7-22
Voetse
Flight distance : 2083 ft
Belgium
Hi,
Im having problems with my Spark since yesterday.
I flew it without any problems for a few minutes, then i landed it without problems.
I charged the battery after that.
Then when i wanted to fly it again i got the ECS error, so i can't fly anymore.
Don't know what went wrong.
I've tried it several times again, but the error keeps showing.
I've got it for 1 week now and just flew it maybe 5 times.
Really dissapointed now.
Can anybody help me?
2017-7-22
Voetse
Belgium
Do i have to kalibrate? Or anything i can do?
2017-7-22
hallmark007
Flight distance : 6342851 ft
Electronic Speed Control, you could try an IMU calibration, it may not help but is wort a try, if not you may have to send back.
They're is new firmware coming next week if you wanted to wait and see if there is a fix in that.
If your going to calibrate leave Spark in a cold room or cold spot for about an hour calibrate on a very level surface.
Good luck.
2017-7-22
Voetse
Belgium
Thanks, I will try this today, hopefully it works
2017-7-22
Monochrome
Flight distance : 12710 ft
Voetse Posted at 2017-7-22 04:10
Try to refresh firmware and then recalibrate IMU if it doesn't help.
2017-7-22
hallmark007
As monochrome said not a bad idea to refresh firmware as well.
2017-7-22
Voetse
Belgium
Still trying, now refreshing software with my Macbook
Recalibrating did not work either
2017-7-22
Voetse
Belgium
Problem still the same
2017-7-22
Voetse
Belgium
Now tried with updating firmware and recalibrating, still does not work.
Guess i'll have to return it to the shop :-(
Anybody some other idea?
2017-7-22
Voetse
Belgium
No more reply's?
2017-7-23
Dirk52
Flight distance : 226257 ft
An appearing esc error is nothing you can fix with firmware or calibration.
You have to send it back. Sorry.
2017-7-23
hallmark007
Hi Voetse, unfortunately having tried to refresh firmware and calibrate your IMU and no change , it looks like you are going to send back to dji.
There was a problem with P4 in the past when putting on prop guards it would trigger ESC warning, this was fixed by doing some calibrations, but was a problem with firmware.
You could end up shorting a motor causing crash or more damage to spark.
Good Luck..
2017-7-23
Voetse
Belgium
Ok,
Thanks
2017-7-23
DJI Natalia
Super Moderator
Flight distance : 318 ft
Voetse, sorry to hear the error is still there after trying basic troubleshooting, it seems the drone needs to be sent in for evaluation. May I know you have contacted the tech support to create a case or not? If yes, please leave me your case number.
To locate where the problem exists, would you please export the data from black box and the flight log showing the situation so I can forward it to engineers for further analysis? Thank you in advance.
Please refer to the tutorial below to get the data, then upload it to Dropbox and post the link here.
2017-7-24
