eylneb
Flight distance : 122477 ft
Malaysia
are you using a smart watch??? putting the smartwatch on airplane mode helps instead of your phone/ipad...
i flew with the following:-
iphone disable bt = same prob, lousy vid signal
iphone disable wifi = same prob, lousy vid signal
iphone enable both = same prob, lousy vid signal
so is not iphone bt or wifi thats causing the prob, so i tested the following
iphone enabled both, apple watch in airplane mode = WAY better (**)
iphone disable bt & wifi & apple watch in airplane mode = not significant improvement from **...
iphone enabled, apple watch enabled, ipad with bt & wifi enabled(connected to RC) = same as above (**)
so now i fly with the following
iphone everything enabled, apple watch in airplane mode; or
iphone, apple watch & ipad, everthing on.. iPad connected to RC
