ImHereToCrash
Flight distance : 5381368 ft
hope they really start adding features we want.
some more features to add i want:
-offline maps on iOS, not just cached maps
- official OTG mode and support (already works why not capitalize on it more)
- Multi Channel use while in OTG with RC, allows the system to capitalize on multiple channels on same band if they are free.
- Default to 2.4Ghz out of the box and on start up.
- Allow users to pick range over video quality (10 Mhz on 2.4Ghz)
- dual band wifi mode, 5.8Ghz and 2.5Ghz and can be used with RC in OTG mode, to extend the range of both video and controls by allowing video and controls to run on separate bands and signals and narrow each band used (hardware is compatible, just not firmware/software feature)
- camera video color filters (simple at least)
- better auto mode for better metering, color, brightness, exposure, focus
- more manual controls / Presets
- offer extended batteries, 20 minutes isn't a huge jump in size and weight, i'm guessing would be 1 extra cell in the pack with a slightly larger battery bump.
- allow faster OA/collision avoidance modes, if you want to test it yourselves, fly in full sport mode (30mph) and fly low enough and pull back on throttle stick full, it can slam its brakes on very fast standing on end.
- if the spark wants to use Atti mode because of some error, alert the user with a slider and discribe with nice pretty popup (like intelligent mode popups) that Atti mode is harder to control, and give option to slide to go to Atti mode or button below to land now and once starts landing to beep on both drone and the RC/App so easier to locate it incase it had to land in an overgrown field or something.. also hover before landing, that way just doubly sure its not hovering over water, give user slider to confirm landing or resposition. this will help prevent flyaways and crashes
-add "safe points" as an alternative to RTH option, mark it on the map manually at the start of session. this way maybe flying very difficult location where you can't trust spark to do it itself, spark got away from you and can't find you while tracking your boat or something, etc etc..or maybe you're planning a 1 way mission (rare) lets say say its a thing maybe search and rescue or exploring something and want to not worry about the battery coming back just want to extend field time, just want to land it there at a safe spot.. then retrieve it once you reach it..
- give another option alternative to RTH, like "return to signal" basically turns around takes same path back until reconnects, if it fails to connect then initiate return to "safe point" manually mark on map at beginning of the fly session.. that way instead of returning to you or your home point which maybe too far, or too difficult for the spark it can land in another location marked.
-disable RTH in gesture mode (d'uh) |
