hallmark007
Flight distance : 9812789 ft
When you press button for 2.4ghz you then have to select a channel, so scroll down just a little, you will first see graph red and green lines, under that there are numbers sliding across just select one, doesn't matter which it will Chanel hop any way, once you have selected you should then see 2.4ghz in your telemetry. |
