Spark :Update 26/7/17
1135 5 2017-7-26
wobbles
Flight distance : 547438 ft
Just to say , the update for spark was ready when i got home for work and it went without a hitch, yea i was suprised tbh ..
1..... Opened up assistant 2 on Macbook
2..... Pluged Sparky in and turned it on
3.... assisatnt said new update so let it do it..NOTE (sparky goes off and on and fan stops sometimes)
4....it all went through and 100% showed completed , pressed back button on screen and turned sparky off..i have 4 battereies so replaced battery and turned back on
then it said inconsiatant or something like that and refreshed update , this agoin took few minutes...DO THIS FOR ALL YOUR BATTERIES..
5...when complete turn all off and unplug
6....start SPARKY up and controller ,and the NEW DJI GO app, which says new update for controller, follow screen prompts NOTE: i had to disconnect WIFI from controller to download the update, but them it says reconnect controller and away it went ....
7 ...finially reboot all devices and try a ickle indoor palm launch and BOOM ...already to go
i know there are videos on how to , but think its important to show a HUMAN doing it and all working ..
hope this helps folks
2017-7-26
lfkiter
Flight distance : 111942 ft
Thanks wobbles, going to use these steps when i get home from work.
2017-7-26
DJI Diana
Flight distance : 2408 ft
Thanks for sharing this with us, this is really helpful.
2017-7-26
wobbles
lfkiter Posted at 2017-7-26 12:45
no probs , how did you get on ?
2017-7-27
lfkiter
Hey, instructions worked well! Thanks again.  Only small detail that I would add is:
6....start SPARKY up and controller ,and the NEW DJI GO app, (make sure to connect to RC wifi) which says new update for controller, follow screen prompts NOTE: i had to disconnect WIFI from controller to download the update, but them it says reconnect controller and away it went ....
When i started everything up, it didn't show RC firmware update until I connected to the remote wifi.  I also didn't disconnect, just used my LTE connection to download the small file and update.
2017-7-27
wobbles
lfkiter Posted at 2017-7-27 11:18
6....start SPARKY up and controller ,and the NEW DJI GO app, (make sure to connect to RD wifi) which says new update for controller, follow screen prompts NOTE: i had to disconnect WIFI from controller to download the update, but them it says reconnect controller and away it went ....
Cool glad it helped , yea that's a good point too .. cheers
2017-7-27
