Bug of hand gesture Active Tracking in new firmware V 01.00.0500
780 11 2017-7-26
Tommy Vu
Flight distance : 4564 ft
Vietnam
Today, after I upgraded firmware of Spark and Controller successfully. Now, I can activate video recording by Hand Gesture " |/ " perfectly.
However, Active Tracking by Hand Gesture "\|/" is not working anymore as it was in the previous firmware version.
At now, I have to connect the smarphone to AC and then manually draw a square on screen for active tracking .
2017-7-26
Dirk52
Flight distance : 226257 ft
For me it is the opposite. Everything works fine except the the new one arm gesture... Any ideas?
Same for me:
2017-7-26
Tommy Vu
Vietnam
Dirk52 Posted at 2017-7-26 23:10
Same for me:
Have you tried video record without connection with Smartphone and fly Indoor (no GPS) ?
2017-7-26
Dirk52
Tommy Vu Posted at 2017-7-26 23:47
I tried it with and without connected Smartphone. But only outdoors.
2017-7-26
fans8400443d
South Korea
tried video gesture with spark only. (no smartphone/RC)
1. normally video works fine
2. doesn't work during "Away and Follow mode" which is very important.
I usually takes video using active track, but gesture video seems doesn't support active track.. so dissapointed
2017-7-27
Dirk52
fans8400443d Posted at 2017-7-27 00:05
This could be!
I tried it only after the away and follow gesture. Why do I want to start recording with 70cm distance to my head??? Come on Dji...
Can you wave the spark away after you started recording? Anyone tried this?
2017-7-27
Tommy Vu
Vietnam
Dirk52 Posted at 2017-7-27 00:22
This could be!
I'll try and leave a result here.
2017-7-27
Dirk52
Tommy Vu Posted at 2017-7-27 02:35
This would be nice. I will try it too.
The new manual says distance must be <2m..this will be the problem after the away and follow gesture.
2017-7-27
Thor1
Flight distance : 196837 ft
that seems like such a waste of time to add that gesture if you cant even use it with active track. that was the whole point of wanting that gesture.
2017-7-27
Convert
Flight distance : 6129 ft
Yes you can. Hand launch, start it recording with a gesture, wave it away and get it to follow. It's all good. A few seconds of random footage of you waving at a drone at the start but that can be edited out easily. bearing in mind it can recognise the photo gesture and the '\|/' gesture at a distance it is odd the video gesture can't be used at distance but it is an easy work around.
2017-7-27
Thor1
Convert Posted at 2017-7-27 03:13
that's not so bad then, thanks for the update.
2017-7-27
Dirk52
Thank you, this will fulfill my needs.
Hopefully dji still don’t set a hp in 0500 when gesture mode with no connected device is active. (=no 100m limit)
2017-7-27
