DJI Diana
Flight distance : 2408 ft
Dixie Flyer Posted at 2017-7-29 10:51
After update I am stuck in beginner mode. I cant go higher than 98 ft (30 meters) or farther than 98 ft from home point. I checked the selection button for beginner mode and it was off. I switched it to on to see what changed. I saw the limitations message, clicked OK and tried to fly again in beginner mode. Same results. Altitude and distance restricted to 98 ft.
Switched it back off and got the message "The sensitivity and speed of aircraft will be substantially increased after disabling Beginner Mode. Fly with caution." Attempted another flight with same problem.
What mobile device are you using? Remove the APP, install it again, then sign in the APP, make sure the beginner mode is disabled, then try to fly it in an open area, see if it works. If it is the same, please try to restart the drone and the APP for several times. |
