OTG not working on spark
12Next >
25815 71 2017-7-27
Spatterfree
Flight distance : 126781 ft
Hi,
finally received my OTG cable, plugged it into my ipad mini 2 and Spark controller but nothing happens, still have to use WIFI to connect to the Spark, anybody know what i can
do to enable it? i am runnnig the latest firmaware. just updated it today.
thanks,
2017-7-27
Lian82
Flight distance : 796775 ft
Before changing Wi-Fi in 2.4ghz then while AC reboots Wi-Fi ... you turn off the smartphone Wi-Fi and enter oTG in the rc and then on the smartphone.
2017-7-27
Spatterfree
so i need to change it to 2.4ghz?
2017-7-27
Lian82
YesI use 2.4ghz because in Italy the 5.8ghz sucks.. try to see if it works with the 5.8ghz I see that you (lucky) live in America.
2017-7-27
Sliderul
Flight distance : 501942 ft
I found the order of connection really makes a difference. If I turn on the RC and the media device then attach the OTG cable; first to the media device, then to the RC, being certain that the OTG adapter or cable end is attached to the RC, I get a connection between the device and the RC. I'm using a Samsung phone and shut down wireless altogether since the OTC connection seems to work so much better.
2017-7-27
Spatterfree
I got it to work once, but this iPad is exclusively to fly the spark, always connected. Do I have to go through that process every time?
2017-7-27
fans9ff6d142
Flight distance : 64865 ft
Plug in the lightning connector first before you insert the micro USB side. It matter which order, I couldn't get mine to work unless I plug in micro USB last.
2017-7-27
Spatterfree
wow, thats almost not worth it, disappointed. between every battery i have to unplug the RC and iPad in order to get it connected again.
also i put it in 2.4ghz and that really put my range down. worked much better in 5.8
2017-7-27
TexasAerials
Flight distance : 566952 ft
it works, just plug it in to phone first, then the remote last.  I went through all my batteries today connected with OTG, and the video came back on after the spark rebooted again each time no problem.
2017-7-27
Kent360
Greece
Hi Spatterfree bit of advice please I am going to order a flymore and want to order OTG cable. Is there any particular spec cable I need? (phone is samsung s6)... or just any otg?
2017-7-27
Spatterfree
Hi Kent,
i had a lightning to microUSB for my iPad, that part worked, but i had to unplug at the controller after each battery to get it connected. also it switched my signal to 2.4ghz which brought my range down to less then half.
2017-7-28
Aerial Ant
Flight distance : 1249715 ft
Sliderul Posted at 2017-7-27 12:07
Bingo! The sequence is the key because at first I thought I had a faulty cable.  Also, my OTG cable works only one way there's a "host" end that goes in the r/c and if its backwards it won't work either. BTW I have iphone and I use a lightning adapter with micro to micro cable.
2017-7-29
Magius
Singapore
If i connect the OTG to the mobile phone end it doesnt work. If I connect the OTG to rc it works.
2017-7-29
fans909d0edb
Flight distance : 19465 ft
what is best brand and length for Android OTG cable. I was hoping for a fairly short micro to micro USB OTG cable. What is everyone using?
2017-7-29
Aerial Ant
fans909d0edb Posted at 2017-7-29 12:58
Try Amazon, many sellers have some of the exact same products with various prices. You can get 1' or 8" cables (I use 1' for phone and tablet use), longer or shorter, OEM or non-OEM cables, different colors, shapes or stronger braided cables. Its personal choice mostly.
2017-7-30
ecf_08
Aerial Ant Posted at 2017-7-29 07:22
Thanks. I simulated it many times and this is the key. I summarized for everyone.
1) Power On Spark
2) Power On RC
3) Connect OTG to Smartphone first then to RC
4) Start DJI Go App 4
5) Go Fly Appears
2017-8-6
ecf_08
ecf_08 Posted at 2017-8-6 15:10
1) Power On Spark
just to add. Smartphone already in airplane mode in step 3. Sometimes a message appears asking you to use this USB accessory by default by this App. Just choose Yes
2017-8-6
PascalG
Flight distance : 274327 ft
As someone Mentioned earlier sequence is important. Connect the lightning cable to otg first, and then connect the otg to controller last. Don't start dji go app till after you get the accessory not supported message
2017-8-6
Bradders
Flight distance : 862283 ft
This cable works perfectly for me http://amzn.to/2vFDS6n
2017-8-6
ecf_08
PascalG Posted at 2017-8-6 17:46
No. for me the DJI app can be started already or not it would not matter...
2017-8-7
ImHereToCrash
Flight distance : 5381368 ft
there is a delay between when phone/tablet will sync to RC via OTG.. i usually pair my spark to RC first.. then i connect my ipad turn off wifi on ipad, and BT... i say wait 30 seconds from sync time till plugging -in in total after syncing RC to spark..    as for direction, RC is the host, so OTG must be RC side.. as for which to plug in first, it's just a cable being repinned mostly so doesn't matter which side goes in first as long as host is RC side..
as for shortened range on 2.4Ghz or 5.8Ghz i have seen both scenarios..depends on location, enviroment and if nature is against you.   if you dont want to fuss around trying to pick the best signal, then once everything is synced up with OTG and wifi and bluetooth is on on the tablet/phone, hold button on back of the spark (on the battery) till it beeps once, let go it should change flashing patterns its now hunting for new signals, on the RC press Pause + FN + C1 and hold it for a couple of seconds after starts rapidly beeping at you (2-3 seconds AFTER it begins beeping rapidly at you), then let it go.. the RC will beep rapidly until the two reconnect on the "best" signal  then in the app you should see a clear picture with little to no lag.  if bad quality or laggy (like half second or more) redo linking process again.
2017-8-7
ZSAY
Flight distance : 7785 ft
Saudi Arabia
ImHereToCrash Posted at 2017-8-7 20:05
Hi ImHereToCrash, you state in your first paragraph "turn OFF Wifi on iPad and BT."
But then you state later in second paragraph "then once everything is synced up with OTG and wifi and bluetooth is ON on the tablet/phone, hold button on back of the spark,,,,"
I'm confused, you turn back ON Wifi and BT again??
2017-8-14
Bobesh
Flight distance : 270840 ft
Czechia
OTG is disabled on iOS devices from the new firmware. From some reports, DJI is working on official support of OTG.
2017-8-14
KeltikCanuk
Flight distance : 52562 ft
Spatterfree Posted at 2017-7-27 12:42
You shouldn't have to disconnect /reconnect OTG when changing batteries. If you follow the connection sequence listed here (RC connection last), you'll be fine through all your battery changes.
2017-8-14
wobbles
Flight distance : 547438 ft
i found this very helpful
2017-8-14
fansbc0b98b2
Hi
I have the Samsung A5 2016 but OTG connection is acting weirdly. like if the phone was trying to charge itself, beeping 2 times every second. Any idea ?
2017-8-19
Bradders
I heard that someone said that the OTG Cables are being cancelled with the new controller update, I have not flown my spark for a while but if so then this will be the only thing that would work most likely, http://amzn.to/2vRFlDL
2017-8-19
fansbc0b98b2
Bradders Posted at 2017-8-19 04:06
thanks, I got the 2 of these and they do not work :
https://www.amazon.fr/gp/product ... 0?ie=UTF8&psc=1
2017-8-19
realstreetuk
Flight distance : 7966 ft
I hope this is not the case, as i only can get to use 2.4 using the OTG method.
2017-8-19
lannes
Flight distance : 4465 ft
Bobesh Posted at 2017-8-14 00:59
Haven't been able to get my ipad mini 4 connected with the OTG, so this must be the reason
2017-8-19
Bobesh
Czechia
lannes Posted at 2017-8-19 05:44
It usually is when someone from DJI says it is disabled on iOS
2017-8-19
lannes
Bobesh Posted at 2017-8-19 12:21
Managed to get OTG on the ipad mini 4 working, just had to follow this sequence, which a slight difference to what was previously listed
1) Ipad on and turn wi-fi off
2) RC on
3) Spark on
4) Wait until RC is connected to Spark (green light on RC)
5) Run DJI GO 4  and Connect OTG to RC
2017-8-20
lannes
realstreetuk Posted at 2017-8-19 05:36
With the ipad mini and OTG, I am getting only 2.4
With the WI-FI connection between the ipad mini and the RC, I get the 5.8 option as well
2017-8-20
lannes
fansbc0b98b2 Posted at 2017-8-19 04:13
https://www.amazon.fr/gp/product/B072N2SN5R/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
maybe it's the sequence of turning on the RC, DJI Go 4 and the AC
2017-8-20
IFrumble-Spark
I have no issues with IPhone 6. Works perfect. I'm still little scared having the spark flying far (>150 meters) away from me. As well between mountains (200 meter wide crack) it's response really funny.
2017-8-20
Bobesh
Czechia
lannes Posted at 2017-8-20 06:23
Interesting
2017-8-22
phatav8r60
not true, I have flown many number of flights in OTG since the update
2017-8-22
Joelling
Flight distance : 76539 ft
Thailand
Despite following the connection sequence, I have noticed that certain usb cables work but not others. But I am still unable to find out the cause of this.
I am using a Samsung S7 btw
2017-8-28
Kladhams
Flight distance : 5020 ft
HI all, I have been trying for a few days now to connect via OTG. I have tried all the different connection methods mentioned above but nothing. I have tried to different android phones, one micro usb (Sony Xperia Z3) and one with type-c (Oneplus 3T) but neither work. The moment wifi is off I get a grey screen and disconnected appears. I really need to find a way around this as I want to have data on (or a way of connecting to the internet) as I live in a Authorisation zone and can't get authorised without connecting to the internet and doing it 24 hours in advanced on a PC is slow.
2017-9-1
freeflightflyin
Flight distance : 7930 ft
UPDATE:
I was also having issues with connecting my phone to the remote. I have found the solution to be by using the otg cable in the remote rather than phone side. I know this has been mentioned before but I didn't quite understand what it meant till now. For anyone else having any similar issues (think I posted mine above). Try switching the otg cable around!
2017-9-1
12Next >
