OTG Cable or WIFI?
123
51995 88 2017-7-28
fansffe041c4
Same question from this newbie Seems like it used to work great, but with new updates, maybe no longer necessary? I just want to get started in the smartest, most efficient way. Thanks!
2018-7-21
sparkdrone
Flight distance : 9593 ft
fans3fcfd5ff Posted at 2017-7-29 15:26
The Amazon page specifically says that this cable is NOT for the Spark.   Did you find some other info that led you to purchase?
Thanks
??? I thought the page said it work for the dji spark too
2019-3-28
sparkdrone
hallmark007 Posted at 2017-7-30 01:57
I have tried both OTG and wifi, there is no difference, spark to RC is working like a dream for me, and no cables is something I don't miss.
I agree there is NO difference, I use Wi-Fi for connecting.
2019-3-28
sparkdrone
OTG cable an WiFi both work, I just use WiFi for myself but it doesn't matter which one you use.
2019-3-28
sparkdrone
rockstarinlife Posted at 2017-8-1 13:48
I use OTG as well. I don't want to take any chances with the wifi signal and lose my Spark.
2019-3-28
sparkdrone
Fix-RE: OTG Cable or WIFI?
OTG and WiFi both work the same, also even if you lose signal the drone returns to the Home Point automatically.
2019-3-28
AntDX316
Flight distance : 3394731 ft
The controller is still connected to the drone.  It's only Wifi to the controller not Wifi to the drone if you got the drone w/ controller package.  I couldn't connect it to the drone w/o the controller.  The Spark does not have it's own Wifi.  When I try to download footage from the drone, OTG and no OTG is still the same.  It still DCs or drops.  I just take it out of the drone and use the micro adapter to Note 9.
OTG is more of a Hassle as the Note 9 is big and requires more intricate maneuvering to make it "sit".
Just need to make sure the Switch to mobile data is ticked off in Wifi settings or it will switch to Mobile disconnecting the Spark especially when it tries to download a Software update but can not.
2019-3-28
AntDX316
Beario Posted at 2018-2-3 07:36
Exactly we use OTG for lag free video.  If anyone uses a larger screen like an ipad the difference is even more obvious.
Mine has the Same amount of lag with OTG or Wifi but it's a Note 9 so it's a better Wifi system I think.
2019-3-28
AntDX316
edit: I think OTG is better as someone said to turn Airplane mode on
2019-3-28
123
