Wellsi
Flight distance : 8330187 ft
MTUFLYER28 Posted at 2017-7-29 20:27
I started with the p3s and it took me about a month before I ended up selling it and buying a Mavic simply because I didn't know if I wanted to put 1000 into a drone. Before I knew it I had nearly 1k into the p3s and it was still lacking in several areas. The biggest issues I had with the p3s was the distance. I believe anything above a standard uses lightbridge which is significantly better range and signal reliability. I would frequently lose signal within a few hundred feet of me and that gets annoying quickly. I ended up getting a range extender and that helped some but still nowhere near the Mavic. As for image quality I don't think a novice user would care. It is only 2.7 k but if your shooting 1080 it doesn't really matter that much. It does not have a lot of the other features the Mavic does such as active track, tripod, point and fly, etc. I had purchased the litchi app for the purpose of using the active track feature and it worked sometimes but was never reliable. The Mavic is obviously much better with the active track. Add in its portability I believe it to be an aveeprall better value.
Hi fella...
Yes, you pretty much summarise it perfectly there. Range really is a huge difference, which is why I laboured that point in the video when I'm flying both drones at the same time.... but as you say, a grand is a lot of money to throw at a hobby you're not sure about, hence the standard is a good first step.... I thought I'd sell mine when I got the Mavic but I'm happy with it in reserve
Cheers
Ian
https://www.youtube.com/IaninLondon
