ImHereToCrash
Flight distance : 5381368 ft
thank you! also, to add if possible few more things should be enabled/added
- ability to manually switch in and out of GPS, ATTi, VPS modes, and assign them to custom buttons on the RC (to help people avoid flyaways during compass errors and allow more experienced users to get better usage)
-enable advanced options like terrain follow, smart return to home, dynamic home point, waypoint, orbit, narrow sensing and wide sensing. (is mods that can enable all of these already as they exist in firmware, so DJi just needs to turn em on and tweak them)
-enable follow mode to follow whatever device it is attached to
-officially update and support OTG, as it is a much better when it works with the native ability to pick desired bands (2.4 or 5.8ghz)
-default to 2,4Ghz on startup and reset, not 5.8ghz, a lot of people have issues with 5.8Ghz, specially EU spec spark users. but 2.4ghz outside has better range potential
- everything i mentioned in the post above!
