DJI Diana
Flight distance : 2408 ft
Like Droneflying mentioned, the DJI Care Refresh does not cover the fly away case. You should retrieve the aircraft and return it to DJI, then you'll be able to replace it under DJI Care Refresh. As for this flight, I would recommend you sync the flight record and export the flight data via DJI assistant 2, then send an email about this to support.us@dji.com, they'll submit a data analysis to find out what happened. |
