Aardvark
Flight distance : 384432 ft
Sports mode will likely show the props if you are moving fast forward. Trying to change the frame rate in editing won't work very well at all.
As Nigel suggested, switch to PAL mode, which will then allow you to use 24 fps natively, and about 1/50th second exposure. Youll get best results if you use ND filters on the P4 as it's fixed aperture.
Best thing would be to do some test runs at home at different frame rates
