BagoDJIoperator
Flight distance : 1077608 ft
Jonimo Posted at 2017-7-30 17:19
Sliding the screen to the right gives you information associated with different drones if there is more than one flown with the same device. I believe lower_version_boardnum is from a flight that didnt end normally, wasn't saved correctly, i had one of those when the dji go app crashed mid flight. You have had a total of 32 flights, 2 of which are listed under "lower_version_boardnum. the left most screen is the total of all drones flight stats. If the lower_version_boardnum thing annoys you, you can delete those 2 flight logs from the dji go app. Hope this helps.
OH okay thanks, I appreciate the response. I did suffer an aircraft disconnect while flying. |
