hallmark007
Flight distance : 9827923 ft
echovictoria Posted at 2017-12-3 16:34
Before my app crashed (Samsung Galaxy S7, latest firmware), (a fact which is scary in itself):
http://www.phantomhelp.com/LogViewer/BKXY8D5K6VRO62QASSE2/
It looks like your Aircraft picked up some magnetic interference, which causes aircraft to go to Atti mode, although you still had control and you can see this through your stick movements, but if it’s out of line of site it can be very difficult.
Your last known coordinates are -37.58243486 143.80638786 you still had 36% battery your aircraft will continue travelling at speed of 16mph until it reaches critical battery then it should land, it would have continued for approx 4/5 minutes at 16 mph so you should be able to roughly work where it might have landed. It may be worth going out for another look to see if you can find it.
Regarding why your Aircraft compass got magnetic interference it looks like it could have been the area you where flying in was it industrial?
You will need to contact dji support to start a case they will review your log and and may be able to tell you more, if you can find your Aircraft it will contain a lot more data.
I’ve seen many similar cases receive warranty but also others who were refused , hopefully you will get a positive there. |
