[Sticky] How to recover video file when power off before stopping recording...
12
67528 62 2014-9-17
Hnscmdn
Tip: The post by the administrator or moderators shield
2016-11-28
Hnscmdn
How to recover lost data from android phone ? once you found the data was lost or deleted on the phone , you must try not to use any phone app , to prevent these lost data has been covered on the phone ,you can noly scan the phone device or memoty with a recovery tools , which can easy access to the phone for scanning , you as long as these data was not covered on the phone , it is possible to recover them ,
2016-11-28
Lily123
There are many reasons that can make MP4 video corrupted, but the applications that can repair MP4 are rare.
Stellar Phoenix MP4 Video Repair can help you fix corrupt/damaged MP4 files.
When to use Stellar Phoenix Video Repair Application:
•        When audio and video are out of sync
•        When you are able to hear sound but the video is not visible
•        When you face movement/header/duration corruption of your MP4 video
•        When video corrupted due to compression issues
•        When your video is corrupt partially or completely
Good luck!
2017-1-17
Marco Bux
finlayson Posted at 2014-9-18 12:12
FYI - I have written (open source) software that can repair many of these files:
http://live555.com/drones/DJI-Phantom-2-Vision+-video-fix/
Hi, Finlayson. Thank you very much for your software. You saved me and my last video and you permitted me to edit and post it on youtube. Great!
I would like to add a little contribution about the recovery process, based on my recent experience.
To edit these kind of videos, I always use AviDemux, with which I only make cuts of segments without any other effects. Every cut is strictly made across the key frames, so that I can save the resultant video as a copy, without any recoding. While editing the repaired video I noticed that, once uploaded to youtube, the image transitions were "disturbed". For example, when a video segment called "A" is attached to a video segment called "B", the transition is like:
...AAABABBB...
instead of:
...AAAABBBB....
This is probably due to a imprecise indexing of the key frames within the repaired file (I suppose). In any case I fixed this issue by recoding the video before the edit process, forcing a keyframe every second (keyint=25). In this way I was able to cut my video with a quite good precision, respecting the (new) keyframes. This is the complete h264 setting that I used for recoding, configured to minimize the quality loss:
  • cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=25 / keyint_min=13 / scenecut=40 / intra_refresh=0 / rc_lookahead=25 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.10 / aq=1:0.50
After that I was able to cut, edit and upload the resultant video, and youtube has not detected flaws anymore.
Hope this can help.
Thanks again.
2017-2-6
RobOnSamui
Thailand
Thanks so much or this! (some years after you posted it!).
I just pecr a week trying every piece of repair software there is. Then I came across this post and it worked right away.
Brilliant!
2017-2-12
GoldenAce57
I just used your code to repair my damaged file. Thank you very much!!!!
2017-2-24
Mrtzr
Turkey
finlayson Posted at 2014-9-19 06:36
Just to clarify - For the software that I wrote (referenced above), I also have pre-built application binaries for both Windows and Mac OS X, so if you're on one of those systems, you don't need to compile anything; just download and run a program (in a command window).  My program - "djifix" - is actually a lot easier to use than "recover_mp4_to_h264" (although they probably do similar things).
Once again, for those who may be interested: http://live555.com/drones/DJI-Phantom-2-Vision+-video-fix/
Too funny, I just sent you an email in regards to how awesome your program is in comparison to the other options available.
I validate this software long before any other "expensive" tool found in the first 10 pages of google search results.
2017-3-20
NinaJ
Thank you so much for writing this piece of software and sharing it! I had a piece of video that was greatly anticipated by some graduating seniors and I thought it was lost forever. Your software, and instructions, worked like a charm. Can't thank you enough for making this available!
2017-4-28
calauza
Flight distance : 102867 ft
Thanks, Ross. djifix still works fine for the phantom 3 corrupt videos, even if the thread is old. But you still need something to convert the h264 to mp4 afterwards, so thanks tony. mp4muxer was the answer for that.
2017-8-21
Bing Err
Flight distance : 9249964 ft
This is AMAZING! I can't believe how many times I've just thrown away files because I thought they were unsalvageable. Can't wait to use this. THANKS
2017-10-14
Wachtberger
Flight distance : 261509 ft
Hi Ross,
I hope you are still around. I have a file that I really would like to repair but this doesn't seem to work under Windows 10 64 bit, or I might be doing something wrong. Can you help me? Thank you!
2017-10-17
Wachtberger
Wachtberger Posted at 2017-10-17 11:39
Hi Ross,
Edit: I have figured out how to do it. Thank you again for the good advice!
2017-10-20
AntBatt13
Flight distance : 138337 ft
Had a video from my P3S I couldn't play, google brought me here and your program worked like a charm! Thanks Ross!!!
2017-11-1
Dogwood
AntBatt13 Posted at 2017-11-1 11:30
For MAC users how are you opening the djifix.dms file to get to djifix?
2018-3-12
alleyn
China
I use Erelive Data Recovery to Recover Deleted Videos in SD, you can get notice from https://www.erelive.com/recover-deleted-videos-from-canon/ . Good luck.
2018-3-25
Geebax
alleyn Posted at 2018-3-25 19:39
It might do, but it will not recover a DJI video file that was not finalised. The issue is not 'deleted' file recovery, it is one of correctly terminating the file.
2018-3-25
Rolfr
Flight distance : 20308 ft
Greece
@Wachtberger
At 2017-10-20 you said you did figured out how to run the 32bit program on 64bit win10. Would be a help if you tell us how.
2018-5-18
4WDaus
Flight distance : 1187257 ft
Dogwood Posted at 2018-3-12 14:22
Just rename the file to remove the .dms This is something safari adds for some reason
2018-7-9
Rudster
Drowned my P4A in Saltwater! Hit lightpost while tracking boat and BANG KERPLUNK! Battery poped out before diving in. Video did not finalize. Im 63 and not a computer wizard. Whats the simplest way to fix file in order to view. It was a beautuful shoot, as whale watching boat entered harbour! Thanks in advance! Rudy in NB
2018-8-29
AliceSmith
Singapore
Thanks for valuable infomation,and there is easier way to recover lost video.Using data recovery program is a efficient and reliable way,since the program has powerful method to scan your device and can list them on program windows,you can preview and choose the target files to recover.
2019-4-8
Geebax
AliceSmith Posted at 4-8 19:38
No, it will not work becuase it is not a deleted file, it is an MPEG file that has not been finalised. The best solution is given in Post #3.
2019-4-8
djiuser_scTRW7CUuyjG
I hate to be that cynical guy, but has anyone verified this? I’ve been burnt too many times before
2019-11-7
Geebax
djiuser_scTRW7CUuyjG Posted at 11-7 10:07
Yes, it works just fine.
2019-11-7
12
